[mesh manipulation] Non-orthogonal cells after refineMesh |
September 14, 2018, 04:10 |
Rep Power: 10 |
Hi all,
I searched the forum but did not find any solution or thread regarding my issue: I use pretty good quality and smooth (pure) hex meshes in OF. Now, I want to refine the mesh using refineMesh and refineHexMesh on well-defined cellSets but neither utility manages to generate a valid mesh. After refinement all (I'm not quite sure but it seems like that) faces of the refined cells are highly non-orthogonal, rendering the result rubbish. The mesh looks appropriate, though. So here's my question: Has anyone encountered the same and maybe found a remedy for this or does someone know what is going wrong here? I can provide checkMesh results before and after as well as some pictures (will do later). Regards and thanks in advance, Martin |
October 29, 2018, 09:30 |
#2 | |
Paul Palladium
Rep Power: 10 |
I am facing exactly the same problem. refineMesh creates non-orthogonal cells when used multiple time on the same cell set. I tried to play with tolerance in controlDict without success. I thought it was due to reconstructParMesh that I used before but it's not the case. I tried the option use geometry or use hex without effect. I also tried to use refineMesh in parallel or in serial (no change !). F |
October 29, 2018, 09:41 |
Rep Power: 10 |
Hi Paul,
well, yet I did not solve my issue but, as my computational results do not seem to be very sensitive to the determined nonorthogonality, I assume it only is a matter of how nonorthogonality is computed for the newly introduced cells containing hanging nodes. I suppose, by splitting cells in octree fashion, the locations of the new cell centroids cause high nonorthogonality where there was none before. I further assume that - given OF can handle hanging nodes by means of flow computations - this nonorthogonality might not pose a 'real' problem but rather the incapability of the mesh checks to account for properly account for hanging nodes. Please, anyone, correct me if I'm wrong... |
August 2, 2019, 13:49 |
Charlie Barraud
Rep Power: 9 |
Hello Paul and Martin,
I am facing the same error after iterating refineMesh on the same cell set. I tried to increase writePrecision in controlDict with no effect. Did you ever find a solution to this problem ? Regards, C. |
August 2, 2019, 14:10 |
Rep Power: 10 |
Hello Charlie,
indeed, I reviewed this specific problem recently. I'm pretty confident, that I have now understood what's the point after reading Juretic's thesis ("Error Analysis in Finite Volume CFD") and having a look at how cfMesh handles "split hexahedra", i.e. hexahedral cells that have been split in such a way that they now have a hanging node on at least one of its six cell faces: Consider two adjacent hex cells, whereby one is decomposed in octree fashion into, say, 2 cells. As OpenFOAM treats any cell generically as arbitrarily polyhedral cell, it does not account in any special way for hanging nodes. Thus, non-orthogonality arises or increases locally as soon as such a non-symmetric (only one cell of a pair) is refined (non-ortghogonality is defined as the angle between the normal vector of the cell-connecting face and the vector connecting the cell centres of two neighbouring cells. The introduced non-orthogonality is thus a "real" numerical concern which reduces accuracy and might result in convergence degradation. I hope this helps but much more I hope I'm right in my interpretation. Anyone correct me please if I'm wrong. |
August 2, 2019, 16:18 |
Charlie Barraud
Rep Power: 9 |
Thank you very much for your answer Martin.
You are totally right. I was using cells with high aspect ratio in one direction. By refining the cells in that direction I was creating non-orthogonal cells. By lowering the aspect ratio in the zone of refinement this issue was solved. C. |
August 6, 2019, 08:27 |
Carlo_P
Rep Power: 7 |
I'm having a similar problem using improveMeshQuality.
I used it, but in the end, I have a worst mesh. You can see the report of checkMesh: before: Max cell openness = 7.35622e-16 OK. Max aspect ratio = 29.7317 OK. Minimum face area = 3.92408e-13. Maximum face area = 1.47856e-07. Face area magnitudes OK. Min volume = 1.60163e-18. Max volume = 3.43724e-11. Total volume = 3.3578e-06. Cell volumes OK. Mesh non-orthogonality Max: 84.9321 average: 12.8083 *Number of severely non-orthogonal (> 70 degrees) faces: 309. Non-orthogonality check OK. <<Writing 309 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 4.04614, 2 highly skew faces detected which may impair the quality of the results <<Writing 2 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. after: Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Inlet_up 4820 5250 ok (non-closed singly connected) Inlet_sx 17145 18233 ok (non-closed singly connected) Outlet 1743 1893 ok (non-closed singly connected) Wall 291922 301087 ok (non-closed singly connected) Checking geometry... Max cell openness = 4.85654e-16 OK. Max aspect ratio = 41.771 OK. Minimum face area = 1.25284e-12. Maximum face area = 1.65683e-07. Face area magnitudes OK. Min volume = 1.20562e-18. Max volume = 3.30891e-11. Total volume = 3.3578e-06. Cell volumes OK. Mesh non-orthogonality Max: 79.9838 average: 18.2811 *Number of severely non-orthogonal (> 70 degrees) faces: 797. Non-orthogonality check OK. <<Writing 797 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 7.31313, 6 highly skew faces detected which may impair the quality of the results <<Writing 6 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End What do you think about? Thanks a lot, Carlo |
August 6, 2019, 10:03 |
Rep Power: 10 |
1. Your problem is not related to "mesh refinement", so I'd advice you to open a new thread, e.g., concering the improveMeshQuality utility (I suppose it belongs to cfMesh)
2. If you have a mesh that bad, an implicit improvement technique will surely not "improve" your mesh. I'm afraid you need to review your first mesh entirely. I suspect you don't capture geometric features well enough achieve a decent quality in that region (or even globally). But this is all speculation. Without seeing your mesh I cannot make any reliable statement. |
April 17, 2020, 09:56 |
#9 |
Athanasios Niotis
Rep Power: 7 |
Hello community,
I have been investigating the same condition two weeks now. I perform wave propagation simulation so i would like to refine the mesh to specific regions close to the water free surface. When i refine one cellSet at the three dimensions it creates non orthogonal mesh; but when i refine it only to Z anisotropicaly the refined cells are purely hexahedral. If anybody has an idea regarding this issue please let us know. Best regards, Thanos |
[snappyHexMesh] Layers not growing at all | zonda | OpenFOAM Meshing & Mesh Conversion | 12 | June 6, 2020 11:28 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ICEM] Problem with prism cells | sidharath | ANSYS Meshing & Geometry | 0 | September 1, 2015 07:09 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
