[Salome] ideasUnvToFoam Error: Assertion `nouveau > -1' failed
Like Tree6Likes
  • 6 Post By GerhardHolzinger
Old   January 29, 2019, 10:23
Default ideasUnvToFoam Error: Assertion `nouveau > -1' failed
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
This is more an answer, than a question.
I have created a geometry with Salome, and created a tet mesh, which I exported in the UNV format. The next step was to convert the mesh using the converter ideasUnvToFoam.
However, I only got this far:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
Build  : 6-4086512c6910
Exec   : ideasUnvToFoam cfdTetMesh.unv
Date   : Jan 29 2019
Time   : 16:07:14
Host   : "userWork"
PID    : 63105
I/O    : uncollated
Case   : /home/user/OpenFOAM/user-6.0/geometries/myCaseFullGeometry/CFD_tetMesh
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Processing tag:164
Starting reading units at line 3.
l:1
units:"  SI: Meter (newton)"
unitType:2
Unit factors:
    Length scale       : 1
    Force scale        : 1
    Temperature scale  : 1
    Temperature offset : 273.15
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 187382 points.
Processing tag:2412
Starting reading cells at line 374787.
First occurrence of element type 11 for cell 1 at line 374788
First occurrence of element type 41 for cell 3529 at line 385372
First occurrence of element type 111 for cell 85459 at line 549232
Read 983696 cells and 81930 boundary faces.
Processing tag:2467
Starting reading patches at line 2516626.
For group 1 named banana trying to read 556 patch face indices.
For group 2 named apple trying to read 556 patch face indices.
For group 3 named orange trying to read 424 patch face indices.
For group 4 named gasOutlet trying to read 76 patch face indices.
For group 5 named bottom trying to read 50 patch face indices.
Sorting boundary faces according to group (patch)
0: banana is patch
1: apple is faceZone
2: orange is patch
3: gasOutlet is patch
4: bottom is patch
Constructing mesh with non-default patches of size:
    banana	556
    orange	424
    gasOutlet	76
    bottom	50
--> FOAM Warning :
    From function Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595
    Found 80824 undefined faces in mesh; adding to default patch.
Adding cell and face zones
 Face Zone apple 	556
ideasUnvToFoam: ideasUnvToFoam.C:1277: int main(int, char**): Assertion `nouveau > -1' failed.
Abgebrochen (Speicherabzug geschrieben)
I tried various versions of OpenFOAM, to no avail. However, when I tried using my foam-extend-4.0 installation, the error message contained the vital hint
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     4.0                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
|    \\/     M anipulation  | For copyright notice see file Copyright         |
Build    : 4.0-246a172c9d9e
Date     : Jan 29 2019
Time     : 16:07:59
Host     : userWork
PID      : 63112
CtrlDict : "/home/user/OpenFOAM/user-6.0/geometries/myCaseFullGeometry/CFD_tetMesh/system/controlDict"
nProcs   : 1
SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Processing tag:164
l:1
unitType:2
Unit factors:
    Length scale       : 1
    Force scale        : 1
Processing tag:2420
Processing tag:2411
Read 187382 points.
Processing tag:2412
Processing tag:2467
    banana	556
    apple	556
    orange	424
    gasOutlet	76
    bottom	50
--> FOAM FATAL ERROR:
Trying to specify a boundary face 3(33 782 6589) on the face on cell 321448 which is either an internal face or already belongs to some other patch.  This is face 0 of patch 1 named apple.
    From function polyMesh::setTopology
    const cellShapeList& cellsAsShapes,
    const faceListList& boundaryFaces,
    const wordList& boundaryPatchNames,
    labelList& patchSizes,
    labelList& patchStarts,
    label& defaultPatchStart,
    label& nFaces,
    cellList& cells
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 357.
FOAM aborting
It turned out, that I messed up my definition of face groups in Salome. Thus, the converter tried and failed to assign the same boundary face to more than one patch.
The error message of the ideasUnvToFoam converter of my foam-extend installation actually reports this error. The ideasUnvToFoam converter of the (foundation) OpenFOAM installations fail with no hint in that regard.
Lessons learned:
  • Keep several OpenFOAM and foam installations on your system, they might turn out to be handy
  • The [CODE]Assertion `nouveau > -1' failed/CODE] error might be caused by duplicate face group membership
dokeun, Muralim, vince_cfd and 3 others like this.
GerhardHolzinger is offline   Reply With Quote
ideasunvtofoam, mesh conversion, salome
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
