[snappyHexMesh] Add Layers in snappyHexMesh
Like Tree9Likes
Old   December 9, 2010, 11:29
Default Add Layers in snappyHexMesh
Mihails Ščepanskis
shchepan is on a distinguished road
I have the problem with adding layers in snappyHexMesh.
My geometry is:
geometry
    topSurfFlat.stl
        type triSurfaceMesh;
        name topSurf;
    sideWall.stl
        name sideWall;
    botWall.stl
        name botWall;
And I try to add layer:
addLayersControls
    relativeSizes true;
    layers
        sideWall
            nSurfaceLayers 1;
    expansionRatio 1.0;
    finalLayerThickness 1.0;
    minThickness 0.9;
    nGrow 1;
    featureAngle 60;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 130;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
But no layer is created:
No layers to generate ...
Layer mesh : cells:835968 faces:2744876 points:1073627
Cells per refinement level:
0 163968
1 120336
2 551664
Writing mesh to time 10.015
Written mesh in = 69.17 s.
Finished meshing in = 403.37 s.
End
What should I do?
Mihails Ščepanskis
Laboratory for Mathematical Modelling of Environmental and Technological Processes
University of Latvia
shchepan is offline   Reply With Quote
Old   June 17, 2012, 02:39
Default Same problem: no layers added
Jeff Kollasch
spatz is on a distinguished road
This is my first post on these forums.
I am having more or less the same exact issue in trying to mesh a boundary layer region on a pipe made in FreeCAD. As the previous poster did (over a year ago) I have explicitly specified patches to add layers in the same way yet find no layers added and a message "No layers to generate ..."
Attached is my case file. I already have made .eMesh files for the edge snapping feature so it can be run by
tar xvzf SimplePipe-SAV02.tar.gz
cd SimplePipe-SAV02
blockMesh
snappyHexMesh
Any suggestion on how to change snappyHexMeshDict will be appreciated. Obviously a lot of people have got this working so I'm sure it's something simple.
spatz is offline   Reply With Quote
Old   June 17, 2012, 06:23
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Haven't ran you case but I'm pretty sure that if you look for "layers" within your sHM log file, you'll see that it's probably complaining about the patch WALL that is not found and it may suggest you to use WALL_patch0 instead.
So WALL_patch0 is what you should have in the layers section of your sHMDict.
amuzeshi likes this.
lovecraft22 is offline   Reply With Quote
Old   June 17, 2012, 14:23
Jeff Kollasch
Thank you so much for your advice. That was exactly my problem. I'm almost there, just having a lot of trouble figuring out what parameter to tweak so the BL region will extend all the way to the inlet and outlet. Does someone know this off-hand?
Thanks for the help.
Jeff
Old   June 17, 2012, 14:55
Jeff Kollasch
Never mind my above post. I found a sufficient example here which should do fine.
https://sites.google.com/site/snappy.../cylinder-case
Thanks again.
uckmhnds likes this.
Old   October 23, 2013, 07:12
R. P.
Rophys is on a distinguished road
Hi all,
I am trying to add a layer in my geometry but I didn't manage to do it.
I already tried to change the patch name, run sHM using geometry in binary and ascii, etc. Could you have a look in my case and give some tip in how to properly add layers on it ? I tried to upload the case here but it's bigger than 97.7 kb. I can send it by email.
Thanks a lot.
Rophys is offline   Reply With Quote
Old   October 23, 2013, 07:17
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Tobias.holzmann@holzmann-cfd.de
Maybe I can have a look today evening.
  • Can you put your Output for the layer adding Phase ?
Tobi is offline   Reply With Quote
Old   October 23, 2013, 08:17
R. P.
Hi Tobias,
Thanks for you quickly response. I tried to upload the out (just the layer part) here, but I got the message: "The text that you have entered is too long (68499 characters). Please shorten it to 20000 characters long".
I sent you the case anyway, you be able to see the output for the sHM.
Thanks again.
Old   October 23, 2013, 13:37
Tobi's Avatar
Tobias Holzmann
For all,
the problem was the OF version.
After starting sHM with 2.2.x everything works fine.
In OpenFOAM-2.1.x I realized that the layer thickness calculation in the beginning is a bit strange. To be sure you have to do the following steps:
1. sHMDict: castellated and snapping on // layer generation off
2. snappyHexMesh -overwrite
3. sHMDict: castellated and snapping off // layer generation on
4. snappyHexMesh -overwrite
Done.
Have Fun.
Old   October 23, 2013, 13:42
R. P.
Yes, it's working perfectly with 2.2.x openFoam version.
Thanks Tobi.
Old   November 4, 2013, 11:53
hasan hasan hasan
hasanmas is on a distinguished road
hallo,
i am also having problems adding layers. i have tried changing many different parameters, but still i cant get the layers to grown. i am sure that i now have the write patch name!
i think its might be the geometry. the best way to describe it would be a flying carpet. a thin wall ( 1- 2 cm thick) but with waved surface. much more like a sail.
could you please help me with some tips or ideas how to solve the problem.
thank you!
hasanmas is offline   Reply With Quote
Old   November 4, 2013, 13:48
Tobi's Avatar
Tobias Holzmann
what is the output of the layer generation?
Old   April 29, 2015, 01:01
Default Add layers in snappyHexMesh _realtive sizes vs absolute
  #13
lav
Lavanya
lav is on a distinguished road
Hi ,
I am running simulation using relative size as "false" in add layers.
I want the first layer thickness to be specific, so I happen to figure out with relative size as false but couldn't understand when set as true.
Please can you detail about how its meshed when it is set as "true". In some tutorials, I have found that its relative to the surface mesh size - -i.e., final layer thickness / surface mesh size. How do I calculate that? Is surface mesh size =Surface area / no of surface elements?
How to go about setting values for maxFaceThicknessRatio and maxThicknessToMedialRatio ?
Thanks
lav is offline   Reply With Quote
Old   April 29, 2015, 05:29
Tobi's Avatar
Tobias Holzmann
check out the snappyHexMesh section in the wiki.
There is a good presentation from Engys. There you find the necessary stuff.
Keep foaming,
Tobias Holzmann
Old   April 29, 2015, 10:39
Philipp Gruschka
pagru is on a distinguished road
Hi everybody,
I'm also having a problem in the layers section of sHM.
In my volume mesh I have two neighbouring regions of different cell density (lets say: R1 and R2), where R2 is twice as dens as R1. (e.g. R1 -> 20 mm cell length; R2 -> 10 mm cell length)
Both regions are bordering a solid wall where boundary layers shall be applied.
The entry "finalLayerThickness" is set to 0.4.
5 Layers shall be applied at the wall.
Since finalLayerThickness is calculated relative to the last cell of the volume mesh, i get boundary layers of different height.
To avoid this, I want to set an override for the finalLayerThickness in region R2. That way, the final layer of both regions has the same height and since the expansion ratio is constant, the remaining cells of the layer will also evolve equally.
THE PROBLEM: I heard that an override for fLT can be set in the layers part like that:
layers
R1 {nSurfaceLayers5;}
R2 {nSurfaceLayers5; finalLayerThickness 0.8;}
expansionRatio 1.25;
finalLayerThickness 0.4;
Unfortunately, during the run of sHM it says that the expression of the override in brackets is "ill defined".
Did anybody encounter a similar problem or has any suggestions to solve this?
Many thanks in advance!
pagru is offline   Reply With Quote
Old   May 5, 2015, 01:19
lav
Lavanya
Hi ,
It should look like the following.
addLayersControls
relativeSizes true;
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.25;
layers
sphere.stl_firstSolid
nSurfaceLayers 1;
maxY
nSurfaceLayers 1;
expansionRatio 1.3;
minThickness 0.1;
frozenPatches
nSurfaceLayers 0;
//Advanced settings
Thanks
minh khang likes this.
Old   May 11, 2015, 09:19
Philipp Gruschka
Thank you very much, i will try that as soon as possible.
However, i tried adding a value for finalLayerThickness directly in the 'layers' section, e.g.:
layers
geoBody (nSurfaceLayers 5; finalLayerThickness 0.8)
This works fine for my problem.
Greetings,
Philipp
Old   November 20, 2015, 03:15
Default How can get the connectivity of Boundary Layer in different Dense of mesh using snapp
  #18
SungTaekPark
probpst is on a distinguished road
Hello guys.
This is the first time to me writing some letter about OpenFOAM.
Any way, in these days, using snappyHexMesh, I have calculated the vessel of KCS with multiphase flow.
But, I don’t know how can I put the layer mesh around the hull well.
Especially, if the Dense of grid is differ from other region(As different Level of refinementRegions)
Then, the boundary layer mesh is just cutting out. I can’t give it the connectivity of layer.
Also, if the surface normal vector is changing suddenly, or something like vessel’s Bulbosbow,
The Boundary layer is also just stopped. Not connected across the surface.
Please check the below picture which is the best snappyHexMeshing for me yet…
Using STAR-CCM, making Grid more easier just like below picture.
Boundary prism layer is well inserted. But, you know Star-CCM is very expensive.
OpenFOAM is Free
Actually, with the current snappyHexMesh, the result of hull’s resistance
is almost correct (1.5 % Error by Experiment Result)
But I still want to find the way how can I make the more stable Grid.
If any one who know the way or get some experience, please give me some tip.
Thank you. ^-^/~
probpst is offline   Reply With Quote
Old   August 26, 2016, 10:36
dupeng is on a distinguished road
Hello, I am doing some similar things with ships. I have created the ship successfully. But like your problem, I cannot seem to create satisfactory boundary layer meshes around the ship. Have you solved your problem? Thank you.
dupeng is offline   Reply With Quote
Old   September 13, 2016, 13:52
Default Hello. Peng.D.U - Regarding snappyHexMesh Boundary Layer - Sorry for late response
  #20
SungTaekPark
Hello. Peng.D.U
It’s nice to contact to you.
First of all, I’m very sorry for late response.
Actually, I do not check my personal E-mail box regularly.
So I couldn’t noticed the E-mail from you. sorry for that any way.
As you said, I think it’s still hard to make Boundary layer satisfactorily using snappyHexMesh.
Not only us, in the OpenFOAM wiki, they also somewhat acknowledged about this problem just like below.
I think the main reason of this is for the sanpping process iteration
which is searching surface boundary from the Outside domain not from the surface it self.
But, it still might be also possible to get a opportunity to generate quite a good quality of Boundary Layer
by adjusting meshQuality such as maximum allowance of skewness, Cell’s orthogonal property and Minimum volume ratio etc.
For example if we adjust increasing “maxNonOrtho more higher and more lower minTetQuality“,
the Boundary Layer could be more better just like below picture
But as you know, the Orthogonal property is very important to get stable iteration during CFD calculation,
so too much allowance of Maximum Non Orthogonality is not good for getting good results.
Also, for getting (y+)=1 condition, the boundary layer might be very thin in some condition,
and this put a restriction on the Generating Boundary layer It self
because of the Maximum Cell aspect ratio, and Min Volume ratio.
But in the case of Model scale’s ship test, the Re number is normally put on the fully turbulent developed area,
So even with somewhat imperfection Boundary layer mesh, the calculation result can be quite a good.
I think this Prism Layer meshing problem is more critical at Propeller analysis.
Normally, the Re number(chord based length) at 70% radios is below than 3.527×106,
the Propeller Open Water test Experiment result might be changed depending onRe. (Re increase -> Kt , Kq decrease)
It means that the flow is on the transient area affected somewhat Laminar condition.
So, in the CFD calculation for this propeller simulation, I think the condition of Boundary prism Layer is quite a important such as giving (y+) < 1
But, it’s still not easy just like below picture(KP505)
So, compromise some of regulating value, and set (y+)=5, I can barely generate below KP505 Propeller mesh.
( I attached MeshQualityDict & snappyHexMeshDict file for this case - check your E-mail Box of pp1565156@126.com )
But, I think it is still not enough for making fully covered Boundary Prism Layer including (y+)< 1
So, I suggest to you another method. May be you already know.
Just Googling “enGrid” . it is also FREE soft ware for only mesh generating.
It is specialized for making Prism Boundary Layer around Object.
But, the Domain mesh consisted of Hexagonal, which is less stable than trimmed mesh(snappyHexMesh)
So, around Object, enGrid can be better solution, and the left Domain area should be made using snappyHexMesh,
And then, merge both two mesh with AMI patch.
I think, above method can be quite a good method for both getting better Boundary Layer and calculating stabilization
even AMI is still uncomfortable.
Oh, it has been long writing,,, any way thank you for contact to me & sorry for late response.
I hope it could be help to you.
Thank you. Have a good day.
Sung Taek Park (probpst)
Naval architecture& Ocean Engineering Department
Seoul national University
South Korea
+82 -10 9408-5375
probpst@snu.ac.kr
amuzeshi, Gang Wang and elsa.manih like this.
[snappyHexMesh] Snappy add layers failed mqsim OpenFOAM Meshing & Mesh Conversion 1 January 24, 2021 15:02
[snappyHexMesh] snappyHexMesh fails adding layers biscarri OpenFOAM Meshing & Mesh Conversion 13 March 21, 2020 12:40
[snappyHexMesh] snappyHexMesh not adding layers to a solid jet_engine OpenFOAM Meshing & Mesh Conversion 0 June 3, 2016 08:25
[snappyHexMesh] snappyHexMesh : Layers on patches Nucleophobe OpenFOAM Meshing & Mesh Conversion 0 October 11, 2012 17:34
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
