[mesh manipulation] SplitMeshRegion
Old   October 28, 2008, 16:03
Default SplitMeshRegion
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi Foamers,
has someone ever tryied to use the splitMeshRegion utility? What does it do?
I'm looking for something that divide my domain in several zones, but I need to avoid internal boundaries, so I want to run from a mesh to the other without crossing patches. Something like a parallel run with domain decomposition (generating processor type patches). Is splitMeshRegion what I need?
Thanks, Ivan
ivan_cozza is offline   Reply With Quote
Old   October 29, 2008, 04:08
Default Regions are subdivisions of me
Mattijs Janssens
mattijs is on a distinguished road
Regions are subdivisions of meshes. See the chtMultiRegionFoam tutorial in 1.5.x.
If this is not what you want you can run decomposePar to generate processor patches. Use the manual option which reads (as far as I remember) a labelList from the constant directory with for every cell the processor it should be in.
mattijs is offline   Reply With Quote
Old   October 29, 2008, 06:38
Default Thank you Mr Janssens, I had
Ivan Flaminio Cozza
I had a look in chtMultiRegionFoam, and my question is: a cell in region 1 that lays just near the region 2 knows what's its neighbour cell in the other region?
[mesh manipulation] splitMeshRegion FekrKon OpenFOAM Meshing & Mesh Conversion 27 June 23, 2020 13:57
[Other] splitMeshRegion problem(cell in multi zones) huangkai OpenFOAM Meshing & Mesh Conversion 0 April 10, 2019 10:52
[mesh manipulation] splitMeshRegion for chtMultiRegionFoamCase Bob! OpenFOAM Meshing & Mesh Conversion 0 February 27, 2017 18:08
cht splitMeshRegion but keeping porous cellZones klilla OpenFOAM Pre-Processing 3 November 19, 2013 08:32
[mesh manipulation] splitMeshRegion Khelian973 OpenFOAM Meshing & Mesh Conversion 1 July 2, 2009 05:02
