[mesh manipulation] CollapseEdges after makeAxialMesh utility in subversion testcase
Old   April 28, 2008, 19:34
Default CollapseEdges after makeAxialMesh utility in subversion testcase
Simone.Sa
bonzodeb is on a distinguished road
Hi all!
When I try to use collapseEdges after makeAxialMesh in the testcase of the subversion MakeAxialMesh utility I receive the same error at all times, with different value of merge angle and edge lenght:
Morphing ...
--> FOAM Warning :
From function boundBox::boundBox(const pointField& points)
in file meshes/boundBox/boundBox.C at line 52
cannot find bounding box for zero sized pointFieldreturning zero
--> FOAM Warning :
Collapsing 0 small edges
Collapsing 0 in line edges
#0 Foam::error::printStack(Foam:stream&) in "/home/openflu/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/openflu/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xb7f1e420]
#3 collapseHighAspectFaces(Foam::polyMesh const&, Foam::PackedList<1> const&, double, double, Foam::edgeCollapser&) in "/home/openflu/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/collapseEd ges"
#4 main in "/home/openflu/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/collapseEd ges"
#5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#6 __gxx_personality_v0 in "/home/openflu/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/collapseEd ges"
Segmentation fault
What's wrong?
Can someone help me to find the right value of edge lenght and merge angle for this testCase?
Thanks
Simone
bonzodeb is offline   Reply With Quote
Old   June 5, 2009, 04:24
Default Problems with collapseEdges
OF_User is on a distinguished road
Hello to all,
has anybody found a solution for this problem? Unfortunately I have the same problem and request your help.
thx,
mike
OF_User is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
Error will loading makeAxialMesh utility in openFOAM-1.6 will_avoid_comm_solvers OpenFOAM 21 October 21, 2014 06:16
collapseEdges (after makeAxialMesh) not worked mechy OpenFOAM 2 November 17, 2011 16:09
makeAxialMesh > collapseEdges!! billynoe OpenFOAM 17 February 21, 2011 05:29
Modification of collapseEdges utility olwi OpenFOAM Bugs 0 September 9, 2008 09:35
