[mesh manipulation] mergePatchPairs on imported mesh
Old   September 19, 2009, 05:16
Default mergePatchPairs on imported mesh
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Hello everybody
What is the procedure to merge 2 meshes in contact on a plane surface, with not coincident nodes ?
The meshes are imported from .unv -> I have polyMesh folder
I tried blockMesh with following blockMeshDict :
convertToMeters 1;
vertices
edges
blocks
patches
mergePatchPairs
  (cyclicDownTrail_1 cyclicDownLead_2)
I obtain following error :
Exec   : blockMesh
Create time
Creating block mesh from
    "/home/nous/OpenFOAM/nous-1.6/run/run/SRF/constant/polyMesh/blockMeshDict"
Creating blockCorners
Creating curved edges
#0  Foam::error::printStack(Foam::Ostream&) in "/home/nous/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1  Foam::sigSegv::sigSegvHandler(int) in "/home/nous/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::arcEdge::arcEdge(Foam::Field<Foam::Vector<double> > const&, Foam::Istream&) in "/home/nous/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#4  Foam::curvedEdge::addIstreamConstructorToTable<Foam::arcEdge>::New(Foam::Field<Foam::Vector<double> > const&, Foam::Istream&) in "/home/nous/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#5  Foam::curvedEdge::New(Foam::Field<Foam::Vector<double> > const&, Foam::Istream&) in "/home/nous/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#6  Foam::blockMesh::createTopology(Foam::IOdictionary&) in "/home/nous/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#7  Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/nous/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#8  main in "/home/nous/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#9  __libc_start_main in "/lib/libc.so.6"
#10  _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Erreur de segmentation
I am not sure to be on the right way. Could anybody advise me ?
Thanks in advance
Jean-Michel
jmf is offline   Reply With Quote
Old   October 1, 2009, 15:10
Default Solved: mergePatchPairs on imported mesh
jmf
Hello
I finally solved my problem: the right way was of course using stitchMesh, instead of mergePatchPairs
Best wishes
J-Michel
mergepatchpairs convert
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
