December 8, 2010, 03:44 |
gmshFoam utility
Zubair Maalick
I am using OpenFoam-1.6 and need to use gmshFoam utility to convert gmsh geometry to openFoam. to Install gmshFoam I have followed following link: http://openfoamwiki.net/index.php/Co...hFoam#gmshFoam The problem I am getting is: after ./Allwmake command I have received following error: . . . . &, const Foam::Xfer<Foam::List<int> >&, bool) /home/openfoam/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/polyMesh.H:219: note: Foam:olyMesh:olyMesh(const Foam::IOobject&) /home/openfoam/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/polyMesh.H:166: note: Foam:olyMesh:olyMesh(const Foam:olyMesh&) polyMeshConversion/polyMeshConversion.C: In member function ‘Foam:olyMeshConversion* Foam:olyMeshConversion::renumberedMesh(Foam::lab el) const’: polyMeshConversion/polyMeshConversion.C:231: error: ‘allFaces’ was not declared in this scope polyMeshConversion/polyMeshConversion.C:264: error: ‘allPoints’ was not declared in this scope make: *** [Make/linuxGccDPOpt/polyMeshConversion.o] Error 1 |
gmshfoam |
OF 6 wallHeatFlux utility not working on chtMultiRegionFoam tutorial | troparry | OpenFOAM Post-Processing | 1 | January 10, 2022 06:12 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
wallHeatFlux Calculation wrt utility version | ahmet | OpenFOAM Post-Processing | 1 | December 18, 2016 19:45 |
[mesh manipulation] mirrorMesh utility preserving regions | zfaraday | OpenFOAM Meshing & Mesh Conversion | 1 | November 7, 2016 21:51 |
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! | zfaraday | OpenFOAM Post-Processing | 0 | February 5, 2015 16:47 |
