[mesh manipulation] visualize the bad elements
Old   August 19, 2011, 04:11
Default visualize the bad elements
ynos
ynos is on a distinguished road
Hi there
How is possible visualize the bad cells with paraview???
Thanks
ynos is offline   Reply With Quote
Old   August 19, 2011, 04:12
ynos
Sorry
I work the mesh with openfoam
Thanks in advance
Old   September 9, 2011, 14:35
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
If you have a set that contains a list of the bad cells, then you can select "include sets" from the object inspector when you first start parafoam. These sets of bad cells can be generated by you, using cellSet, or they can be those produced by checkMesh utility. Hope that helps.
Dan
chegdan is offline   Reply With Quote
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
[ICEM] Bad elements along a curved vanes Julian121 ANSYS Meshing & Geometry 2 October 21, 2018 07:15
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
[ICEM] How to improve bad quality elements that are obtained after creating prism layers? Rohith Giridhar ANSYS Meshing & Geometry 2 July 11, 2015 18:04
