[mesh manipulation] using mergeMeshes and stitchMesh
Old   October 12, 2011, 13:42
Default using mergeMeshes and stitchMesh
vladimir krejci
Lada is on a distinguished road
I have created two very simple cases consisting of a cube and a cylinder. I have successfully blockmeshed them but I am struggling with joining the cases together.
Actually, I had managed it once and even noted what I did, but apparently I must have missed something as I have not been capable of repeating the whole action and get the joint case running.
Could anyone give me a hint and/or write here the right procedure, please?
Lada is offline   Reply With Quote
Old   October 13, 2011, 02:25
Tomislav Maric
tomislav_maric is on a distinguished road
I've written up the procedure in this thread:
http://www.cfd-online.com/Forums/ope...hes-p-t-u.html
Hope it helps!
Tomislav
tomislav_maric is offline   Reply With Quote
Old   October 13, 2011, 15:04
vladimir krejci
That was it. Thank you Tomislav.
Lada
case set-up, mergemeshes, stitchmesh
[mesh manipulation] StitchMesh sigFpe / bad point liquidspoon OpenFOAM Meshing & Mesh Conversion 2 November 29, 2015 14:19
[mesh manipulation] mergeMeshes and stitchMesh in parallel? samiam1000 OpenFOAM Meshing & Mesh Conversion 1 June 6, 2014 10:21
[mesh manipulation] Problem with stitchMesh: it does not work in meshes with several common patches arnau1985 OpenFOAM Meshing & Mesh Conversion 2 June 25, 2013 08:49
[mesh manipulation] stitchMesh and mergeMeshes removal of interfaces flowris OpenFOAM Meshing & Mesh Conversion 6 July 16, 2010 12:06
[mesh manipulation] MergeMeshes and stitchMesh problem flo OpenFOAM Meshing & Mesh Conversion 6 May 10, 2010 10:40
