[mesh manipulation] Get elevation profile between 2 points on STL
Old   February 3, 2012, 12:09
Default Get elevation profile between 2 points on STL
ic3wall is on a distinguished road
Is there a tool in OpenFoam I could use to find the elevation profile (xyz preferably) between two given points on an STL file.
Here's what I want to do:
I have a large topo map in STL format, I define a diamond domain in blockMesh with 8 vertices and then run MoveDynamicMesh. See picture of the result below. On the picture you see only the inlet patch.
From that, I need to have the inlet elevation profile in order to extrude it on a given distance to run a cyclic simulation on it. Then, I want to map the results of the inlet of this cyclic simulation on the inlet of my diamond domain (both profiles are supposed to be the same).
To map the results from one simulation to another, not only for MapFields, but for me it's important that both profiles are identical.
In summary, I need to extrude the mesh of the inlet patch shown below ..
Please help!
ic3wall is offline   Reply With Quote
Old   February 3, 2012, 12:23
ok for those looking do to something silimar, there exists a tool called extrudeMesh.
It does exactly what I wanted!
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 08:26
OpenFoam restarting simulation, stops at first Time loop syntex OpenFOAM Running, Solving & CFD 4 April 5, 2019 11:20
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 07:05
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[General] Free Surface Elevation (Profile) Jing_min ParaView 1 December 26, 2012 18:24
