Error when solving with simpleFoam fora file converted from Gmesh
Hello Everyone,
I had converted a .msh file using the gmshToFoam command and when i run the simpleFoam solver i get the following: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : simpleFoam Date : Apr 22 2012 Time : 12:20:32 Host : "openFoam" PID : 2132 Case : /opt/openfoam210/VelocityCaseLaminar nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::surfaceInterpolation::makeWeights() const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #4 Foam::surfaceInterpolation::weights() const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #5 in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/simpleFoam" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/simpleFoam" Floating point exception I'm quite new to the OpenFoam and don't know how to solve this problem. If anybody is familiar with this problem, please advise me on how to proceed. Thanks Guy |
Similar error
Hi Guy,
I have the same problem with my simulation. The mesh seems to be good, I defined all the boundary face and conditions, and when I launch simpleFoam I have the exact same message that appears. Have you figured out your problem? I'm kind of desperate, I've already double checked all my geometry, direction of the faces and I'm out of any new idea to solve this problem. If you found the solution could you please tell me how to proceed. Thanks. Maxime eading field p Reading field U Reading/calculating face flux field phi #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::surfaceInterpolation::makeWeights() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #4 Foam::surfaceInterpolation::weights() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #5 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/simpleFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/simpleFoam" Exception en point flottant |
Hi Maxime,
I had managed to solve this problem. In my opinion (and please take into consideration i'm not an expert in OpenFoam...) there are two possible options, either you convert youe model/workspace to be axisymmetric and use the wedge option for your front and back patches, or you can make the width along the z axis (from front to back, direction) greater. I had used both in two different solutions, on the later option, for a model with a characteristic lenth of a 100 meters, i had changed the width from 1 meter to 10 meters and that had solved the problem. Best of luck, Guy |
