Meshing a disc like this
Hello everyone !
I'm a new user of OpenFOAM and I wish realise a mesh of this type, but i don't really know how to do it : http://www.cfd-online.com/OpenFOAM_D...ges/1/4060.jpg Somebody can help me to start ? I have understood how to mesh differents types of cubes (such as with an arc of circle) but i have no idea for start to mesh a circle/a disc. Thank you (and sorry for my bad english :D) Marine |
I don't think you will be able to mesh this with blockMesh, because blockmesh will create hexahedral cells, however exactly at the center you have tetrahedral cells. the easiest way to create such a disc is to make a block in the center and then create quarter circle blocks on every side.
Thank for your rapid answer.
If I understood correctly,, your idea is to create a central block then create many quarter circle block around. You think it's possible to realise a maillage like this with four blocks and create arcs of circle inside the blocks ? |
I think the following can help you. You can create arc also on the inside of the block, but you won't have a disc then, but a ring, which has just a very small hole in the center. 5 blocks (1 center block, 4 blocks on the outside, where the ones on the outside have arcs as boundaries) is the standard to create round objects with hexahedral cells.
http://www.cfd-online.com/Forums/ope...arge-mesh.html |
Thank, I studying your link and then, after, I try to meshing a disc.
It is possible and even very easy to do it with blockMesh.
You can check for example this link http://www.somogyibence.hu/documents...sh_O-Grid.html for learning about how to work with blockMesh. Greetings Ivan |
Thank you so much Ivan.
1.Divide the circle in 4 quadrants, assume the point (0,0,0) to be at the center of the disc.
2.find the coordinates of all the vertices of the quadrants relative to this point. (eg: (5,0,0) (0,5,0) (-5,0,0) (0,-5,0). 3. specify the same vertices for say z=10 4.specify that edges 0-1. 1-2, et al are arcs, while following the correct syntax. 5.form the block. 6. give "empty" bc for faces at z=10, z=-10. |
