May 21, 2012, 09:53 |
FluentMeshToFoam
Carles
I have a mesh file created with icem, I would like to do the simulations in OpenFOAM. I used FluentMeshToFoam to convert my file and use it. When I check the mesh all seems to be ok, however when I try to visualize the mesh with paraFoam, I can open the file and visualize the outline, but when i switch to wireframe the program breaks as well as my computer. Do you think that there is a problem with my Mesh, maybe with paraFoam? What i did in detail 1. fluent.msh file (2D unstructured mesh) converted using FluentMeshToFoam in a case folder . Within this case folder I have a system folder with the main files ( controlDict, fvSchemes and fvSolution), another folder 0 which is empty, and a constant folder with the g, Rasproperties and Transportproperties files. from this step I get. " Create time Dimension of grid: 2 Number of points: 906697 Reading points Number of cells: 899548 Other readCellGroupData: d 1 db9dc 1 0 Reading mixed cells number of faces: 1806259 Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Read zone1:13 name:FLU patchTypeID:fluid Reading zone data Read zone1:14 name:int_FLU patchTypeID:interior Reading zone data Read zone1:15 name:WALL patchTypeID:wall Reading zone data Read zone1:16 name:AXIS patchTypeID:axis Reading zone data Read zone1:17 name:INLET patchTypeID:mass-flow-inlet Reading zone data Read zone1:18 name:GAPTOP patchTypeIDutflow Reading zone data FINISHED LEXING dimension of grid: 2 Grid is 2-D. Extruding in z-direction by: 0.00781488 Creating shapes for 2-D cells Building patch-less mesh...--> FOAM Warning : From function polyMesh:olyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 614 Found 1823356 undefined faces in mesh; adding to default patch. done. Building boundary and internal patches. Creating patch 0 for zone: 14 start: 1 end: 1781999 type: interior name: int_FLU Creating patch 1 for zone: 15 start: 1782000 end: 1804452 type: wall name: WALL Creating patch 2 for zone: 16 start: 1804453 end: 1806185 type: axis name: AXIS Creating patch 3 for zone: 17 start: 1806186 end: 1806249 type: mass-flow-inlet name: INLET Creating patch 4 for zone: 18 start: 1806250 end: 1806259 type: outflow name: GAPTOP Creating patch for front and back planes Patch int_FLU is internal to the mesh and is not being added to the boundary. Adding new patch WALL of type wall as patch 0 Adding new patch AXIS of type symmetryPlane as patch 1 Adding new patch INLET of type patch as patch 2 Adding new patch GAPTOP of type patch as patch 3 Adding new patch frontAndBackPlanes of type empty as patch 4 Writing mesh... to "constant/polyMesh" done. End " If i check the mesh I get: " carles@ISMGT31:~/OpenFOAM/carles-2.1.0/run/2> checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.x-97cf67d69932 Exec : checkMesh Date : May 21 2012 Time : 15:40:40 Host : ISMGT31 PID : 7832 Case : /home/carles/OpenFOAM/carles-2.1.0/run/2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 1813394 internal points: 0 faces: 3605355 internal faces: 1781999 cells: 899548 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 889614 prisms: 9934 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology WALL 22453 44910 ok (non-closed singly connected) AXIS 1733 3468 ok (non-closed singly connected) INLET 64 130 ok (non-closed singly connected) GAPTOP 10 22 ok (non-closed singly connected) frontAndBackPlanes 1799096 1813394 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-4.73491e-12 0 -0.00390744) (0.38 0.091 0.00390744) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (-6.20526e-17 -3.94744e-16 2.47734e-20) OK. Max cell openness = 2.33542e-16 OK. Max aspect ratio = 4.02168 OK. Minumum face area = 3.67793e-09. Maximum face area = 3.57831e-06. Face area magnitudes OK. Min volume = 2.87426e-11. Max volume = 1.281e-09. Total volume = 0.000242844. Cell volumes OK. Mesh non-orthogonality Max: 20.4403 average: 4.16882 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.622065 OK. Coupled point location match (average 0) OK. Mesh OK. End " All seems to be right 2. I run paraFoam, select just internalMesh and then click apply. The program load the file, but as i said, when in the display menu i switch to wireframe the program is collapsed even the computer so I have to "restart" my computer in a bad way... I hope someone could help me, at least to give some advice about possible errors, because itīs quite strange due to I could visualize it some time ago. I donīt know why I canīt visualize it any more... I changed the graphic card of my computer, but i think itīs not the problem since i could visualize another mesh from tutorials cases so on. Thanks a lot, Carles. |
May 22, 2012, 16:06 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Carles,
Try running like this: Code:
paraFoam -builtin Bruno
May 24, 2012, 06:12 |
Carles
Hi bruno,
Thanks for your reply. What does this command do? I didnīt try and the program seems to work. Thatīs why i donīt want to touch nothing else . those interested check: http://http://www.cfd-online.com/For...tml#post362852 greetings, Carles |
May 24, 2012, 16:07 |
Bruno Santos
Rep Power: 128 |
Hi Carles,
When in doubt: Code:
paraFoam -help Best regards, Bruno
fluentmeshtofoam, parafoam |
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" | preibie | OpenFOAM Meshing & Mesh Conversion | 28 | March 29, 2017 04:56 |
[Commercial meshers] Converting an abaqus mesh using matlab scripts and fluentMeshToFoam | MichaelD | OpenFOAM Meshing & Mesh Conversion | 1 | July 2, 2014 06:34 |
[Commercial meshers] fluentMeshToFoam instead of fluent3DMeshToFoam | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | March 29, 2013 07:58 |
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam | jlpelerin | OpenFOAM Meshing & Mesh Conversion | 4 | April 25, 2011 16:56 |
[Commercial meshers] Error fluentMeshToFoam | loneboard | OpenFOAM Meshing & Mesh Conversion | 26 | February 6, 2009 10:20 |
