Refinement edges
5 Attachment(s)
Hi Foamers,
the figure shows the inlet and outlet of my cooler. I would to ask you how i can obtain the similar result in proximity of edges. The concentric layers are important to study turbulence model. This geometry comes from fluent export. Any ideas?? |
Hi Vincenzo,
your "snappyHexMeshDict" looks good. If your layer cells don't get filtered by the quality settings, then this should be fine. (You could switch off all quality controls and check what it looks like then. Then carefully raise quality controls until "checkMesh" gives you an OK ... << see this post) So why are there no layer cells?: Assuming, that the images you posted are the full geometry, then here is a possible answer: snappyHexMesh cannot make layer cells orthogonal to a boundary. They will always start growing at a boundary edge. So unless you will cut your geometry in half in paraview/parFoam you will not see, whether there are any layers and what they look like. You could use a cutting plane for that, or better "extractedCellsByRegion". SOLUTION: AFAIK there is no solution for that problem. Though it might be possible to extend the geometry at the boundary, then snappyHexMesh the extended version of your mesh and afterwards cut the extended part off. But this is only a idea ... I never tried it. Greets, Jan |
Thanks so much Jan!! I'm tried several options. We'll inform about the progress.
Greets, vinezio |
Hi Vincenzo,
I just came across a possible solution: If you set your "inlet"-patch to patch type "empty" in your blockMeshDict then snappyHexMesh will give you orthogonal cell layers. No need for cutting! e.g. Code:
... Afterwards you will need to change the patch type in the "boundary"-file located under "constant/polyMesh/" to type "patch". Here's the link for reference: https://sites.google.com/site/snappy.../cylinder-case Greets, Jan |
