[Other] How to create zero thickness internal walls in a given mesh in OpenFOAM? |
July 6, 2012, 07:34 |
notyet
Rep Power: 13 |
I know using topoSet and subsetMesh along the lines of the mesh/moveDynamicMesh/simpleHarmonicMotion tutorial, one can cut holes into a mesh and obtain new patches. How can something similar be achieved with a vanishing hole, i.e. can a set of internal faces be turned into two touching patches with opposite orientation?
-- also posted at http://scicomp.stackexchange.com/q/2715/1669 |
July 9, 2012, 05:13 |
notyet
Rep Power: 13 |
As gschaider posted at SE, I simply need to use the createBaffles tools
Display Modes | |
[Other] Internal Walls in mesh | Rakkiran | OpenFOAM Meshing & Mesh Conversion | 6 | April 15, 2021 03:48 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
Create thickness for zero thickness surface mesh | zonexo | Mesh Generation & Pre-Processing | 0 | May 28, 2016 12:35 |
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall | sebastian | OpenFOAM Meshing & Mesh Conversion | 6 | October 21, 2010 05:36 |
