[blockMesh] How to use blockMesh to generate cylindrical T-junction |
July 12, 2012, 21:45 |
Bin Xu
Hi Forums, I am new to OpenFOAM. I am struggling to use blockMesh to generate cylindrical T-junction geometry. Can anyone give clue or can post a simple blockMeshDict file that is two cylinder with same diameter then intersect to form a T-junction? Many thanks
January 26, 2013, 02:08 |
starter
Hi
I have tried to do it because this is also my problem but I am getting errors on this one. If you have done it already perhaps you can guide me, convertToMeters 0.001; vertices ( (0 0 0) // point 0 (0 0 60) // point 1 (0 0 -60) // point 2 (0 60 0) // point 3 (0 -60 0) // point 4 (1500 0 0) // point 5 (1500 0 60) // point 6 (1500 0 -60) // point 7 (1500 60 0) // point 8 (1500 -60 0) // point 9 (690 0 60) // point 10 (810 0 60) // point 11 (750 60 60) // point 12 (750 -60 60) // point 13 (750 0 750) // point 14 (690 0 750) // point 15 (810 0 750) // point 16 (750 60 750) // point 17 (750 -60 750) // point 18 ); blocks ( hex (1 3 2 4 6 8 7 9) (20 20 1) simpleGrading (1 1 1) hex (11 12 10 13 16 17 15 18) (20 20 1) simpleGrading (1 1 1) ); edges ( arc 1 3 (0 30 50) arc 3 2 (0 30 -50) arc 2 4 (0 -30 -50) arc 4 1 (0 -30 50) arc 6 8 (0 30 50) arc 8 7 (0 30 -50) arc 7 9 (0 -30 -50) arc 9 6 (0 -30 50) arc 11 12 (50 30 0) arc 12 10 (-50 30 0) arc 10 13 (-50 -30 0) arc 13 11 (50 -30 0) arc 16 17 (50 30 0) arc 17 15 (-50 30 0) arc 15 18 (-50 -30 0) arc 18 16 (50 -30 0) ); boundary ( fixedWalls { type wall; faces ( (1 2 3 4) (6 7 8 9) (15 16 17 18) (1 3 6 8) (3 2 8 7) (2 4 7 9) (4 1 9 6) (11 12 16 17) (12 10 17 15) (10 13 15 18) (13 11 18 16) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // |
January 28, 2013, 20:53 |
Bin Xu
Hi, my T-junction is formed by two cylinders, where the interface is not a arc which cannot be obtained by blockMesh. I just use GID to generate mesh and then import to OpenFOAM. Can you give a schematic illustration about your geometry and the location of each point? Best regards
[blockMesh] External flow around cube with blockMesh | Woody8 | OpenFOAM Meshing & Mesh Conversion | 0 | March 31, 2015 14:54 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 08:37 |
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh | colinB | OpenFOAM Meshing & Mesh Conversion | 8 | January 22, 2012 10:32 |
How to generate tetrahedral/hybrid grids by blockmesh | Tarak | OpenFOAM | 0 | October 4, 2010 15:00 |
Cylindrical Obstacle Simulation | Abdelraheem | Main CFD Forum | 0 | August 5, 2010 05:57 |
