[blockMesh] --> FOAM FATAL ERROR: Trying to specify a boundary face
Like Tree1Likes
Old   November 25, 2014, 09:37
seav is on a distinguished road
Originally Posted by slash89 View Post
Trying to specify a boundary face 4(1 5 6 2) on the face on cell 0 which is either an internal face or already belongs to some other patch. This is face 0 of patch 2 named outlet2.
Two options:
1. This an internal face and its not allowed to do this.
2. You messed something with point-order in blocks.
Give us more information, sent ur blockMeshDict file or simply paste it here with
code
function.
Cheers,
seav
"OpenFOAM is like a strict teacher, won't let you through until all is correct or better say until one has understood the sensitivities of a problem." -jaswi
seav is offline   Reply With Quote
Old   November 25, 2014, 09:43
slash89 is on a distinguished road
This is the boudary's part of blockMeshDict:
boundary
inlet
type patch;
faces
(0 4 7 3)
outlet1
type patch;
faces
(2 6 5 1)
outlet2
type patch;
faces
(2 6 5 1)
wall
type patch;
faces
(0 3 2 1)
(3 7 6 2)
(1 5 4 0)
(4 5 6 7)
I got one inlet and two outlet. The outlet are on the same face but something doesn't work.
Thak you,
Best Regards
slash89 is offline   Reply With Quote
Old   November 25, 2014, 12:04
This is not enough info. Post your block(); and vertices(); section.
Cheers,
seav
Old   November 25, 2014, 13:06
convertToMeters 0.001;
a 40;
b 60;
c 30;
xi -500;
xf 250;
yi -350;
yf 160;
zi 400;
zf 600;
vertices
($xi $yi $zi) //0
($xf $yi $zi) //1
($xf $yf $zi) //2
($xi $yf $zi) //3
($xi $yi $zf) //4
($xf $yi $zf) //5
($xf $yf $zf) //6
($xi $yf $zf) //7
blocks
hex (0 1 2 3 4 5 6 7) ($a $b $c) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 4 7 3)
outlet1
type patch;
faces
(2 6 5 1)
outlet2
type patch;
faces
(2 6 5 1)
wall
type patch;
faces
(0 3 2 1)
(3 7 6 2)
(1 5 4 0)
(4 5 6 7)
This is the entire file. I'm sorry but the upload doesn't work!
Thank you
Old   November 25, 2014, 13:55
a 40;
b 60;
c 30;
xi -500;
xf 250;
yi -350;
yf 160;
zi 400;
zf 600;
vertices
($xi $yi $zi) //0
($xf $yi $zi) //1
($xf $yf $zi) //2
($xi $yf $zi) //3
($xi $yi $zf) //4
($xf $yi $zf) //5
($xf $yf $zf) //6
($xi $yf $zf) //7
blocks
edges
boundary
inlet
type patch;
faces
(0 4 7 3)
outlet1
type patch;
faces
(2 6 5 1)
wall
type patch;
faces
(0 3 2 1)
(3 7 6 2)
(1 5 4 0)
(4 5 6 7)
Didnt check this on OF but I guess it will work. The reason is becouse u set outlet1 and outlet2 in the same points. Its not allowed.
If any error accure study this : http://www.openfoam.org/docs/user/blockMesh.php (figure 5.5) to set correct points in hex() function.
Cheers,
seav
Old   November 26, 2014, 03:28
Thank you, the code is the same as my old one, when I had only one outlet. Now i got 2 outlet, should I use your code, will it work? What about the boundary? with your code i will have only 3 boundary: inlet outlet1 and wall but i need the temperature also on the second outlet.
Best regards
Old   November 26, 2014, 10:38
You are defining two outlets, outlet1 and outlet2 on the same face. Its not allowed. I dont know what you want to achive but...
..there was a way to define 2 boundary in the same area (not face):
1. Make double vertices of points 5 1 2 6 - just copy them.
2. Make outlet2 with new vertices.
3. Use mergePatchPairs(); to connect 2 different faces.
I am not sure if it helps, it worked few months ago.
Maybe you could describe your geometry more precisely.
Cheers,
seav
Old   June 6, 2016, 07:14
Fatemeh
fatemehfarshi62 is on a distinguished road
Hi every one! I have the same problem with the blockMesh file attached. when running, it says:
Trying to specify a boundary face 4(143 144 248 247) on the face on cell 52 which is either an internal face or already belongs to some other patch. This is face 91 of patch 1 named walls.
my version of openfoam is 2.4
Can any one please help me with it?
first, what does this error mean?
second, what can I do for it?
fatemehfarshi62 is offline   Reply With Quote
Old   June 6, 2016, 07:17
Fatemeh
first, what does it mean?
second, what can I do for that?
Old   June 7, 2016, 04:34
Antimony is on a distinguished road
Why have you defined the same block twice??
    hex (117 118 144 143 221 222 248 247) (30 140 4) simpleGrading (2 2 2) //b32lfp(after //b27rfp)
     hex (117 118 144 143 221 222 248 247) (30 140 4) simpleGrading (2 2 2) //b32lfp (after //b32rfp)
Relook at your definitions to ensure that they are correct, before you mesh.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   June 8, 2016, 00:45
Fatemeh
Hi Antimony!
Thank you again and again for helping me so much. problem solved!
Thanks and best wishes
Old   July 13, 2016, 09:54
Madeleine
Madi is on a distinguished road
Hi to all,
I've got the same problem like Karla had.
Face 6403 specified in set bar is not an external face of the mesh.
This application can only repatch existing boundary faces.
I look in paraview like bruno said. But my face should be in the right position. I dont know what to do now. If someone can have a look i would be glad.
Thanks!
File Type: zip sets.zip (608 Bytes, 1 views)
Madi is offline   Reply With Quote
Old   October 31, 2016, 23:52
Unhappy foam fetal error
  #33
razieh khaksari
baran khaksari is on a distinguished road
hi every one. I try to simulate a compartment with a door in front door and a ventilation on the roof but I faced this error when run blockMesh.
Trying to specify a boundary face 4(12 15 14 13) on the face on cell 2 which is either an internal face or already belongs to some other patch. This is face 5 of patch 3 named empty.
From function polyMesh::setTopology
const cellShapeList& cellsAsShapes,
const faceListList& boundaryFaces,
const wordList& boundaryPatchNames,
labelList& patchSizes,
labelList& patchStarts,
label& defaultPatchStart,
label& nFaces,
cellList& cells
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 355.
FOAM aborting
the below lines are my blockMesh. please help me
convertToMeters 1;
vertices
(0 0 0)
(3.6 0 0)
(3.6 3 0)
(0 3 0)
(0 0 2.4)
(3.6 0 2.4)
(3.6 3 2.4)
(0 3 2.4)
(1.425 0 2.4)//point8
(2.175 0 2.4)//point9
(2.175 2 2.4)//point10
(1.425 2 2.4)//point11
(1.425 0 1.7)//point12
(2.175 0 1.7)//point13
(2.175 2 1.7)//point14
(1.425 2 1.7)//point15
(1.425 0 0.7)//point16
(2.175 0 0.7)//point17
(2.175 2 0.7)//point18
(1.425 2 0.7)//point19
(1.425 0 0)//point20
(2.175 0 0)//point21
(2.175 2 0)//point22
(1.425 2 0)//point23
(1.425 3 2.4)//point24
(2.175 3 2.4)//point25
(2.175 3 1.7)//point26
(1.425 3 1.7)//point27
(2.175 3 0.7)//point28
(1.425 3 0.7)//point29
(1.425 3 0)//point30
(2.175 3 0)//point31
blocks
hex (0 20 30 3 4 8 24 7) (10 20 20) simpleGrading (1 1 1)
hex (21 1 2 31 9 5 6 25) (10 20 20) simpleGrading (1 1 1)
hex (12 13 14 15 8 9 10 11) (5 10 10) simpleGrading (1 1 1)
hex (16 17 18 19 12 13 14 15) (5 10 10) simpleGrading (1 1 1)
hex (20 21 22 23 16 17 18 19) (5 10 10) simpleGrading (1 1 1)
hex (15 14 26 27 11 10 25 24) (5 10 10) simpleGrading (1 1 1)
hex (19 18 28 29 15 14 26 27) (5 10 10) simpleGrading (1 1 1)
hex (23 22 31 30 19 18 28 29) (5 10 10) simpleGrading (1 1 1)
edges
boundary
fixedWalls
type wall;
faces
(7 4 0 3)//left
(30 24 7 3)
(7 24 8 4)
(6 2 1 5)
(9 5 6 25)
(25 6 2 31)
(12 13 9 8)
(16 17 13 12)
(20 21 17 16)
(23 22 21 20)
(11 10 25 24)
(25 26 27 24)
(29 28 31 30)
(30 31 22 23)
inlet
type patch;
faces
(9 10 11 8)//door
outlet
type patch;
faces
(28 29 27 26)//roof
empty
type empty;
faces
(24 11 15 27)
(24 30 20 8)
(25 9 21 31)
(10 14 13 9)
(11 8 12 15)
(12 15 14 13)
(15 14 13 12)
(15 14 10 11)
(14 10 11 15)
(19 18 14 15)
(18 14 15 19)
(14 18 17 13)
(15 12 16 19)
(19 18 17 16)
(18 17 16 19)
(18 22 21 17)
(19 16 20 23)
(23 22 18 19)
(22 18 19 23)
(25 26 14 10)
(27 26 14 15)
(26 14 15 27)
(26 28 18 14)
(27 15 19 29)
(29 28 18 19)
(28 18 19 29)
(28 31 22 18)
(29 19 23 30)
mergePatchPairs
baran khaksari is offline   Reply With Quote
Old   November 1, 2016, 04:42
(12 15 14 13), or in a similar form, is part of two blocks - block 2 & block 3 (index starts from 0). As a result I can't see how it can be a boundary face....
Make sure your mesh definitions are correct.
Cheers,
Antimony
Old   November 1, 2016, 07:23
razieh khaksari
Thank alot
Old   November 26, 2016, 15:18
Emre
ordinary is on a distinguished road
Hello everyone,
I have same annoying problem, too. I think documentation about creating block meshes are not satisfying.
Here is the problem. Sorry but I couldn't upload the whole blockMeshDict file due to the this website. So here is the code:
convertToMeters 1;
vertices
(0 25 0) //0
(20 25 0) //1
(20 30 0) //2
(0 30 0) //3
(0 25 0.02) //4
(20 25 0.02) //5
(20 30 0.02) //6
(0 30 0.02) //7
(40 25 0) //8
(40 30 0) //9
(40 25 0.02) //10
(40 30 0.02) //11
(80 25 0) //12
(80 30 0) //13
(80 25 0.02) //14
(80 30 0.02) //15
(0 5 0) //16
(20 5 0) //17
(40 5 0) //18
(80 5 0) //19
(0 5 0.02) //20
(20 5 0.02) //21
(40 5 0.02) //22
(80 5 0.02) //23
(0 0 0) //24
(20 0 0) //25
(40 0 0) //26
(80 0 0) //27
(0 0 0.02) //28
(20 0 0.02) //29
(40 0 0.02) //30
(80 0 0.02) //31
blocks
hex (0 1 2 3 4 5 6 7) (48 35 1) simpleGrading (0.90909 1.1 1)
hex (1 8 9 2 5 10 11 6) (1000 35 1) simpleGrading (1 1.1 1)
hex (8 12 13 9 10 14 15 11) (55 35 1) simpleGrading (1.1 1.1 1)
hex (16 17 1 0 20 21 5 4) (48 1000 1) simpleGrading (0.90909 1 1)
hex (17 18 8 1 21 22 10 5) (1000 1000 1) simpleGrading (1 1 1)
hex (18 19 12 8 22 23 14 10) (55 1000 1) simpleGrading (1.1 1 1)
hex (24 25 17 16 28 29 21 20) (48 35 1) simpleGrading (0.90909 0.90909 1)
hex (25 26 18 17 29 30 22 21) (1000 35 1) simpleGrading (1 0.90909 1)
hex (26 27 19 18 30 31 23 22) (55 35 1) simpleGrading (1.1 0.90909 1)
edges
boundary
inlet
type patch;
faces
(0 4 7 3)
(16 20 4 0)
(4 7 3 0)
outlet
type patch;
faces
(12 13 15 14)
(10 12 14 23)
(27 19 23 21)
top
type patch;
faces
(3 7 6 2)
(2 6 11 9)
(9 11 15 13)
bottom
type patch;
faces
(28 24 25 29)
(29 25 26 30)
(30 26 27 31)
frontAndBack
type empty;
faces
(3 2 1 0)
(0 1 16 17)
(16 17 24 25)
(2 9 1 8)
(1 8 17 18)
(17 18 25 26)
(9 13 8 12)
(8 12 18 19)
(18 19 26 27)
(5 6 7 4)
(21 5 4 20)
(29 21 20 28)
(10 11 6 5)
(22 10 5 21)
(30 22 21 29)
(14 15 11 10)
(23 14 10 22)
(31 23 22 30)
mergePatchPairs
ordinary is offline   Reply With Quote
Old   December 22, 2016, 21:11
Why is the face (0 4 7 3) pretty much specified twice?
inlet
type patch;
faces
(0 4 7 3)
(16 20 4 0)
(4 7 3 0)
Cheers,
Antimony
Old   January 31, 2017, 04:48
Emre
Thank you very much for your attention. Unfortunately it is too late for me to respond your reply but yes it was a mistake. I specified it twice. I figured it out and changed the whole file because of it also had several errors.
Thank you again.
Old   May 24, 2018, 11:22
Cristina Hernandez
crizpi21 is on a distinguished road
Hi everyone,
I am new to OpenFOAM and I got stuck with this same error when creating my mesh:
Trying to specify a boundary face 4(12 16 18 14) on the face on cell 1 which is either an internal face or already belongs to some other patch. This is face 0 of patch 4 named square.
I would be very grateful if anyone could help me. This is my blockMeshDict
convertToMeters 10;
vertices
// x y z
(0 0 -0.005) //0
(1 0 -0.005) //1
(1 0.6 -0.005) //2
(0 0.6 -0.005) //3
(0 0 0.005) //4
(1 0 0.005) //5
(1 0.6 0.005) //6
(0 0.6 0.005) //7
(0.3 0 -0.005) //8
(0.4 0 -0.005) //9
(0.3 0 0.005) //10
(0.4 0 0.005) //11
(0.3 0.25 -0.005) //12
(0.4 0.25 -0.005) //13
(0.3 0.25 0.005) //14
(0.4 0.25 0.005) //15
(0.3 0.35 -0.005) //16
(0.4 0.35 -0.005) //17
(0.3 0.35 0.005) //18
(0.4 0.35 0.005) //19
(0.3 0.6 -0.005) //20
(0.4 0.6 -0.005) //21
(0.3 0.6 0.005) //22
(0.4 0.6 0.005) //23
(0 0.25 -0.005) //24
(0 0.35 -0.005) //25
(0 0.25 0.005) //26
(0 0.35 0.005) //27
(1 0.25 -0.005) //28
(1 0.35 -0.005) //29
(1 0.25 0.005) //30
(1 0.35 0.005) //31
blocks
//Block 0
hex (0 8 12 24 4 10 14 26) (20 20 1) simpleGrading (1 1 1)
//Block 1
hex (24 12 16 25 26 14 18 27) (20 10 1) simpleGrading (1 1 1)
//Block 2
hex (25 16 20 3 27 18 22 7) (20 20 1) simpleGrading (1 1 1)
//Block 3
hex (8 9 13 12 10 11 15 14) (10 20 1) simpleGrading (1 1 1)
//Block 4
hex (12 13 17 16 14 15 19 18) (10 10 1) simpleGrading (1 1 1)
//Block 5
hex (16 17 21 20 18 19 23 22) (10 20 1) simpleGrading (1 1 1)
//Block 6
hex (9 1 28 13 11 5 30 15) (50 20 1) simpleGrading (1 1 1)
//Block 7
hex (13 28 29 17 15 30 31 19) (50 10 1) simpleGrading (1 1 1)
//Block 8
hex (17 29 2 21 19 31 6 23) (50 20 1) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 4 26 24)
(24 26 27 25)
(25 27 7 3)
outlet
type patch;
faces
(1 28 30 5)
(28 29 31 30)
(29 2 6 31)
top
type patch;
faces
(3 7 22 20)
(20 22 23 21)
(21 23 6 2)
bottom
type patch;
faces
(0 8 10 4)
(8 9 11 10)
(9 1 5 11)
square
type wall; //obstacle in the flow
faces
(12 16 18 14)
(16 17 19 18)
(13 15 19 17)
(13 12 14 15)
mergePatchPairs
Cheers!
crizpi21 is offline   Reply With Quote
Old   May 25, 2018, 03:47
Cristina Hernandez
Originally Posted by crizpi21 View Post
Hi everyone,
convertToMeters 10;
vertices
// x y z
(0 0 -0.005) //0
(1 0 -0.005) //1
(1 0.6 -0.005) //2
(0 0.6 -0.005) //3
(0 0 0.005) //4
(1 0 0.005) //5
(1 0.6 0.005) //6
(0 0.6 0.005) //7
(0.3 0 -0.005) //8
(0.4 0 -0.005) //9
(0.3 0 0.005) //10
(0.4 0 0.005) //11
(0 0.25 0.005) //26
(0 0.35 0.005) //27
(1 0.25 0.005) //30
(1 0.35 0.005) //31
blocks
//Block 0
//Block 1
//Block 2
//Block 3
//Block 4
//Block 5
//Block 6
//Block 7
//Block 8
edges
boundary
inlet
type patch;
faces
(0 4 26 24)
(24 26 27 25)
(25 27 7 3)
outlet
type patch;
faces
(1 28 30 5)
(28 29 31 30)
(29 2 6 31)
top
type patch;
faces
(3 7 22 20)
(20 22 23 21)
(21 23 6 2)
bottom
type patch;
faces
(0 8 10 4)
(8 9 11 10)
(9 1 5 11)
square
faces
(12 16 18 14)
(16 17 19 18)
(13 15 19 17)
(13 12 14 15)
mergePatchPairs
Cheers!
I found the error: the problem was that I had specified the inner block (//Block 4
hex (12 13 17 16 14 15 19 18) (10 10 1) simpleGrading (1 1 1)).
Hence, the faces of this block were already internal faces, so when I wanted to define them in the square boundary as "walls", it said they already belonged to another path.
I hope this helps, cheers!
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
