Hi every one! I have the same problem with the blockMesh file attached. when running,
| ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) //0 (0.914 0 0) //1 (0 1.93 0) //2 (0.914 1.93 0) //3 (0 3.93 0) //4 (0.914 3.93 0) //5 (0 5.59 0) //6 (0.914 5.59 0) //7 (0 0 0.296) //8 (0.914 0 0.296) //9 (0 1.93 0.296) //10 (0.914 1.93 0.296) //11 (0 3.93 0.296) //12 (0.914 3.93 0.296) //13 (0 5.59 0.296) //14 (0.914 5.59 0.296) //15 (0 0 0.51) //16 (0.914 0 0.51) //17 (0 1.93 0.51) //18 (0.914 1.93 0.51) //19 (0 3.93 0.51) //20 (0.914 3.93 0.51) //21 (0 5.59 0.51) //22 (0.914 5.59 0.51) //23 (8.334 5.59 0) //24 (8.334 6.504 0) //25 (6.404 5.59 0) //26 (6.404 6.504 0) //27 (2.404 5.59 0) //28 (2.404 6.504 0) //29 (0.914 5.59 0) //30 (0.914 6.504 0) //31 (8.334 5.59 0.296) //32 (8.334 6.504 0.296) //33 (6.404 5.59 0.296) //34 (6.404 6.504 0.296) //35 (2.404 5.59 0.296) //36 (2.404 6.504 0.296) //37 (0.914 5.59 0.296) //38 (0.914 6.504 0.296) //39 (8.334 5.59 0.51) //40 (8.334 6.504 0.51) //41 (6.404 5.59 0.51) //42 (6.404 6.504 0.51) //43 (2.404 5.59 0.51) //44 (2.404 6.504 0.51) //45 (0.914 5.59 0.51) //46 (0.914 6.504 0.51) //47 (0 5.59 0) //48 (0 6.504 0) //49 (-3.546 5.59 0) //50 (-3.546 6.504 0) //51 (-7.546 5.59 0) //52 (-7.546 6.504 0) //53 (-15.546 5.59 0) //54 (-15.546 6.504 0) //55 (0 5.59 0.296) //56 (0 6.504 0.296) //57 (-3.546 5.59 0.296) //58 (-3.546 6.504 0.296) //59 (-7.546 5.59 0.296) //60 (-7.546 6.504 0.296) //61 (-15.546 5.59 0.296) //62 (-15.546 6.504 0.296) //63 (0 5.59 0.51) //64 (0 6.504 0.51) //65 (-3.546 5.59 0.51) //66 (-3.546 6.504 0.51) //67 (-7.546 5.59 0.51) //68 (-7.546 6.504 0.51) //69 (-15.546 5.59 0.51) //70 (-15.546 6.504 0.51) //71 ); blocks ( hex (0 1 3 2 8 9 11 10) (10 10 10) simpleGrading (1 1 1) hex (8 9 11 10 16 17 19 18) (10 10 10) simpleGrading (1 1 1) hex (2 3 5 4 10 11 13 12) (10 10 10) simpleGrading (1 1 1) hex (10 11 13 12 18 19 21 20) (10 10 10) simpleGrading (1 1 1) hex (4 5 7 6 12 13 15 14) (10 10 10) simpleGrading (1 1 1) hex (12 13 15 14 20 21 23 22) (10 10 10) simpleGrading (1 1 1) hex (24 25 27 26 32 33 35 34) (10 10 10) simpleGrading (1 1 1) hex (32 33 35 34 40 41 43 42) (10 10 10) simpleGrading (1 1 1) hex (26 27 29 28 34 35 37 36) (10 10 10) simpleGrading (1 1 1) hex (34 35 37 36 42 43 45 44) (10 10 10) simpleGrading (1 1 1) hex (28 29 31 30 36 37 39 38) (10 10 10) simpleGrading (1 1 1) hex (36 37 39 38 44 45 47 46) (10 10 10) simpleGrading (1 1 1) hex (30 31 49 48 38 39 57 56) (10 10 10) simpleGrading (1 1 1) hex (38 39 57 56 46 47 65 64) (10 10 10) simpleGrading (1 1 1) hex (48 49 51 50 56 57 59 58) (10 10 10) simpleGrading (1 1 1) hex (56 57 59 58 64 65 67 66) (10 10 10) simpleGrading (1 1 1) hex (50 51 53 52 58 59 61 60) (10 10 10) simpleGrading (1 1 1) hex (58 59 61 60 66 67 69 68) (10 10 10) simpleGrading (1 1 1) hex (52 53 55 54 60 61 63 62) (10 10 10) simpleGrading (1 1 1) hex (60 61 63 62 68 69 71 70) (10 10 10) simpleGrading (1 1 1) ); edges ( ); boundary ( inletMain { type patch; faces ( (24 25 33 32) (32 33 41 40) ); } inletBranch { type patch; faces ( (0 1 9 8) (8 9 17 16) ); } lowerWall { type wall; faces ( (0 1 3 2) (2 3 5 4) (4 5 7 6) (24 25 27 26) (26 27 29 28) (28 29 31 30) (30 31 49 48) (48 49 51 50) (50 51 53 52) (52 53 55 54) ); } middleLayer { type patch; faces ( (8 9 11 10) (10 11 13 12) (12 13 15 14) (32 33 35 34) (34 35 37 36) (36 37 39 38) (38 39 57 56) (56 57 59 58) (58 59 61 60) (60 61 63 62) ); } atmosphere { type patch; faces ( (16 17 19 18) (18 19 21 20) (20 21 23 22) (40 41 43 42) (42 43 45 44) (44 45 47 46) (46 47 65 64) (64 65 67 66) (66 67 69 68) (68 69 71 70) ); } fixedWallRight { type wall; faces ( (1 3 11 9) (9 11 19 17) (3 5 13 11) (11 13 21 19) (5 7 15 13) (13 15 23 21) (25 27 35 33) (33 35 43 41) (27 29 37 35) (35 37 45 43) (29 31 39 37) (37 39 47 45) (31 49 57 39) (39 57 65 47) (49 51 59 57) (57 59 67 65) (51 53 61 59) (59 61 69 67) (53 55 63 61) (61 63 71 69) ); } fixedWallLeft { type wall; faces ( (0 8 10 2) (8 16 18 10) (2 10 12 4) (10 18 20 12) (4 12 14 6) (12 20 22 14) (24 32 34 26) (32 40 42 34) (26 34 36 28) (34 42 44 36) (28 36 38 30) (36 44 46 38) (30 38 56 48) (38 46 64 56) (48 56 58 50) (56 64 66 58) (50 58 60 52) (58 66 68 60) (52 60 62 54) (60 68 70 62) ); } outlet { type patch; faces ( (55 54 62 63) (63 62 70 71) ); } ); // ************************************************** *********************** // --> FOAM FATAL ERROR: Trying to specify a boundary face 4(8 9 11 10) on the face on cell 0 which is either an internal face or already belongs to some other patch. This is face 0 of patch 3 named middleLayer. From function void Foam::polyMesh::setTopology(const cellShapeList&, const faceListList&, const wordList&, Foam::labelList&, Foam::labelList&, Foam::label&, Foam::label&, Foam::cellList&) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 324. |
topoSet::createPatchDict
1 Attachment(s)
Hallo foamers,
I know this is a old thread, but i got stuck in a similar problem. I extracted a faceSet (6 faces) using topoSet, and when i try to create patch from it, it throws following error. Please have a look at the picture, and let me know, what's wrong. https://www.dropbox.com/sh/sxq5vj3lm...B4M8VaK2a?dl=0 Code:
