"Cannot find point in pts1" and other errors
Hello All!
I am trying to make a very complicated mesh with cyclic bc on a couple of sides. I am getting following errors, the seriousness of which I do not understand as the meshing does take place eventually. Attached below is the error. Please let me know what do these errors mean so that I can make necessary modifications. Thanks for your time. Regards, Nikunj. Cannot find point in pts1 matching point 1665 coord:(13.6082 4.41765 19.75) in pts0 when using tolerance 2.8401e-05 Searching started from:1664 in pts1 Compared coord:(13.2205 4.30581 19.75) with difference to point 0.403521 Compared coord:(13.604 4.43052 19.75) with difference to point 0.0135356 cyclicPolyPatch::order : Writing neighbour faces to OBJ file "/home/eri/OpenFOAM/eri-2.1.1/run/tutorials/incompressible/icoFoam/cavity2/right_faces.obj" cyclicPolyPatch::order : Writing my faces to OBJ file "/home/eri/OpenFOAM/eri-2.1.1/run/tutorials/incompressible/icoFoam/cavity2/left_faces.obj" cyclicPolyPatch::order : Dumping currently found cyclic match as lines between corresponding face centres to file "/home/eri/OpenFOAM/eri-2.1.1/run/tutorials/incompressible/icoFoam/cavity2/left_faceCentres.obj" --> FOAM Serious Error : From function cyclicPolyPatch::order(const primitivePatch&, labelList&, labelList&) const in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 1383 Patch:left : Cannot match vectors to faces on both sides of patch Perhaps your faces do not match? The obj files written contain the current match. Continuing with incorrect face ordering from now on! <<Number of duplicate (not baffle) faces found: 1. This might indicate a problem. <<Number of faces with non-consecutive shared points: 2. This might indicate a problem. Writing polyMesh ---------------- Mesh Information ---------------- boundingBox: (5.571 -4.48 0) (14.5 4.48 19.95) nPoints: 94675 nCells: 86976 nFaces: 268364 nInternalFaces: 254210 ---------------- Patches ---------------- patch 0 (start: 254210 size: 85) name: master_patch1 patch 1 (start: 254295 size: 100) name: master_patch2 patch 2 (start: 254395 size: 34) name: master_patch3 patch 3 (start: 254429 size: 34) name: master_patch4 patch 4 (start: 254463 size: 1666) name: right patch 5 (start: 256129 size: 1666) name: left patch 6 (start: 257795 size: 2751) name: outer_sides patch 7 (start: 260546 size: 2499) name: inner_sides patch 8 (start: 263045 size: 48) name: vent_walls patch 9 (start: 263093 size: 1734) name: top patch 10 (start: 264827 size: 1743) name: bottom patch 11 (start: 266570 size: 9) name: inlet patch 12 (start: 266579 size: 1785) name: defaultFaces End |
Hello Nikunj,
I had a similar error message using stitchMesh and that way found this thread. Did you scale any part of your mesh ? That might cause this problem. Try to scale at the very end of the process, hope that helps... Arne |
I get a similar error, see here: http://www.cfd-online.com/Forums/ope...tml#post465466 Did you guys figure out, what the problem was? Best regards Julian |
