[mesh manipulation] Mesh Editing OpenFOAM?
Like Tree1Likes
  • 1 Post By wyldckat
Old   December 21, 2012, 22:19
Default Mesh Editing OpenFOAM?
j.t.
turbfoam is on a distinguished road
Hi, I have an existing fine mesh which I want to make very coarse.
The mesh is not generated by me, so I have the mesh only as a plot3d file which I converted to openFOAM using plot3dToFoam....Hence no blockmeshDict file to change mesh density easily.
Any mesh utility in OpenFOAM to do this? Can anyone please point me towards any reference/tutorial for that? if not OpenFOAM what other software you suggest.
thank for your help very much....
cheers,
J.T.
turbfoam is offline   Reply With Quote
Old   December 26, 2012, 16:58
Retired Super Moderator
Bruno Santos
Hi J.T.,
I did see this thread the other day, and I saw just now your request on the other thread about "peturbU".
The short answer is, AFAIK: there is no such generic mesh application that "unrefines" meshes. At least not in OpenFOAM.
But there are some possibilities in OpenFOAM that can come close, depending on the mesh you've got:
  • polyDualMesh will construct a new mesh based on a tetrahedral mesh: http://openfoamwiki.net/index.php/PolyDualMesh
  • OpenFOAM relies on an octree refinement scheme of hex meshes, which allows it to regress back a refinement it has done before. This is done auto-magically for dynamic meshes, but I have yet to see it being used for coarsening a mesh.
    In theory, you could run the application refinementLevel for calculating the possible refinement level that was used in the mesh, but only in cartesian meshes. After that... I have no clue.
About the octree feature... I this was discussed in this thread: http://www.cfd-online.com/Forums/ope...am2-0-1-a.html
edit: for future reference, the following threads are on the same subject:
Best regards,
Bruno
shang likes this.
[Salome] Problems for creating mesh in salome to OPENFOAM bye bye my blue OpenFOAM Meshing & Mesh Conversion 8 December 5, 2023 00:57
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM nsf OpenFOAM Meshing & Mesh Conversion 86 February 8, 2023 10:30
[Commercial meshers] OpenFoam Mesh to Fluent Mesh in parallel case DominicTNC OpenFOAM Meshing & Mesh Conversion 3 November 22, 2017 09:19
[Salome] Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 02:54
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
