[snappyHexMesh] snappyHexMesh with zero Thickness surface imported from a Geometry |
September 4, 2012, 11:41 |
Rep Power: 13 |
Hello!
I have a Geometry of an Umbrella structure (in dwg format) [see the attached photo] and I need to do a wind simulation on it using OpenFOAM As far as I know, I need to make an STL file. The problem is that the membrane part of the Umbrella is surfaces (not a solid) so I could not make an STL file out of it. One approch is to give the membrane a thickness (convert it to solid) I did that. but when asking autoCAD to export it as an STL the membrane is messed up! My question is: Is there a way to make an STL file including zero Thickness surface?! or Is there a way to use snappyHexMesh without doing the STL step? if there is, how to deal with the internal faces in openFoam? Can I deal with them as patches and assign BC to them? Thanks for your help! |
[snappyHexMesh] Problems meshing an impeller with snappyHexMesh | kandelabr | OpenFOAM Meshing & Mesh Conversion | 13 | June 9, 2017 06:18 |
[snappyHexMesh] problem with snappyHexMesh | kanes | OpenFOAM Meshing & Mesh Conversion | 10 | January 26, 2016 06:11 |
SnappyHexMesh... Domain boundaries are uneven | Blue8655 | OpenFOAM Pre-Processing | 0 | January 20, 2016 11:43 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] SnappyHexMesh AddLayer Control | rdrr84 | OpenFOAM Meshing & Mesh Conversion | 28 | May 30, 2014 05:32 |
