[snappyHexMesh] Need help to improve my snappyHexMesh mesh |
October 6, 2014, 05:10 |
amine
Rep Power: 12 |
Hi
I created mesh with snappyHexMesh but I have some problem to have good mesh (see picture). Can anyone help me to ameliorate my mesh. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location system; object snappyHexMeshDict; } castellatedMesh true; snap true; addLayers true; geometry { cuve1.stl { type triSurfaceMesh; name cuve1; } cuve2.stl { type triSurfaceMesh; name cuve2; } cuve3.stl { type triSurfaceMesh; name cuve3; } P3.stl { type triSurfaceMesh; name P3; } P4.stl { type triSurfaceMesh; name P4; } shaft.stl { type triSurfaceMesh; name shaft; } P4MRF { type searchableCylinder; point1 ( 0.0 -0.0035 0.0 ); point2 ( 0.0 0.0465 0.0 ); radius 0.05; } P3MRF { type searchableCylinder; point1 ( 0.0 0.135 0.0 ); point2 ( 0.0 0.185 0.0 ); radius 0.05; } } castellatedMeshControls { features ( ); refinementSurfaces { cuve1 { level ( 0 0 ); } cuve2 { level ( 0 0); } cuve3 { level ( 0 0 ); } P3 { level ( 0 2 ); } P4 { level ( 0 2 ); } shaft { level ( 0 2 ); } P4MRF { faceType internal; faceZone MRFP4; cellZoneInside inside; cellZone MRFP4; level ( 0 0 ); } P3MRF { faceType internal; faceZone MRFP3; cellZoneInside inside; cellZone MRFP3; level ( 0 0 ); } } refinementRegions { P4MRF { mode inside; levels (( 1E5 2 )); } P3MRF { mode inside; levels (( 1E5 2 )); } } locationInMesh ( 0.0 0.0 0.05 ); maxLocalCells 100000; maxGlobalCells 2000000; minRefinementCells 0; nCellsBetweenLevels 1; resolveFeatureAngle 30; allowFreeStandingZoneFaces true; planarAngle 30; maxLoadUnbalance 0.10; } snapControls { nSolveIter 30; nSmoothPatch 3; tolerance 2.0; nRelaxIter 5; nFeatureSnapIter 10; implicitFeatureSnap true; explicitFeatureSnap true; multiRegionFeatureSnap true; } addLayersControls { layers { cuve2 { nSurfaceLayers 3; } cuve3 { nSurfaceLayers 3; } P3 { nSurfaceLayers 3; } P4 { nSurfaceLayers 3; } shaft { nSurfaceLayers 3; } } relativeSizes true; expansionRatio 1.2; finalLayerThickness 0.3; minThickness 0.25; nGrow 0; featureAngle 130; slipFeatureAngle 30; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; writeVTK false; noErrors false; layerRecovery 1; growZoneLayers false; projectGrownUp 0.0; } meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minFlatness 0.5; minVol 1.00E-13; minTetQuality 1e-15; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; } debug 0; mergeTolerance 1E-6; autoBlockMesh true; |
October 8, 2014, 04:47 |
amine
Rep Power: 12 |
Any ideas???
October 11, 2014, 10:59 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings aminem,
You could have been a bit more specific regarding what exactly you want to improve. Either way, the one thing I say that needs work is related to this dictionary block: Code:
features ( ); You can find a lot of reading material on this and other topics regarding snappyHexMesh, meshing strategies and visual diagnosis in this wiki page: http://openfoamwiki.net/index.php/SnappyHexMesh Best regards, Bruno
Display Modes | |
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh | JD_Welch | OpenFOAM Meshing & Mesh Conversion | 10 | July 5, 2023 12:50 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 17:59 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
