[mesh manipulation] decomposePar of directMapped Patches with metis
Like Tree1Likes
  • 1 Post By chegdan
Old   September 9, 2011, 11:50
Default decomposePar of directMapped Patches with metis
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
I have seen several threads about the direct mapped patches in parallel:
http://www.cfd-online.com/Forums/ope...apped+parallel
And I know that we have to keep faces that are being mapped to and from on the same processor (owners and neighbors). However, I'm too complex to use the "simple" method in my decomposePardict and I want to be complex and use "metis". This is where this question is different, the use of metis.
So, how does one use preserveFaceZones properly so that the to and from faces are on the same processor? Right now, I have my two patches inlet and outlet at two ends of domain. I map the outlet to the inlet and everything is happy. I then tried to use preservefacezones by creating a set using faceSet made from the faces of my inlet and outlet together in a set creatively called directMappedSet. Using setsToZones, i populated the faceZones file in polyMesh and then added:
method metis;
preserveFaceZones (directMappedSet);
to my decomposeParDict file and decomposed my case. Upon checking my processor meshes, i found that it did not decompose how I expected. Some informational messages I received were:
Calculating distribution of cells
Keeping owner and neighbour of faces in zones
1
directMappedSet
 on same processor
Selecting decompositionMethod metis
Selected 42924 faces whose owner and neighbour cell should be kept on the same processor
--> FOAM Warning :
    From function min(const UList<Type>&)
    in file /home/dcombest/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/FieldFunctions.C at line 342
    empty field, returning zero
Finished decomposition in 23.18 s
So, long story for a simple question...how does one decompose a complex geometry so that directMapped patches work properly in parallel?
Dan
hua1015 likes this.
chegdan is offline   Reply With Quote
Old   October 31, 2012, 15:48
ic3wall is on a distinguished road
Did you solve this ?
I also have to run a case containing directMapped boundary condition in parallel...
ic3wall is offline   Reply With Quote
Old   November 1, 2012, 04:53
Daniel P. Combest
At the time I had a workaround, but i think this has been taken care of in another bugfix. Give it a try and if there is an issue I can look at it again.
Old   November 1, 2012, 08:21
I found that depending how I decompose, sometimes the simulation starts without problems, sometimes it stops at time 1. It says cpus are 100% busy but nothing happens.
Do you know if it's important to keep the directMapped zone (like cyclic) on the same processor or it doesn't matter ?
Old   November 1, 2012, 08:42
Daniel P. Combest
unless they changed this, if I remember correctly you must keep the coupled patches an the same processor in the same subdomain.
Old   November 1, 2012, 20:31
When using directMapped, no patches are coupled.
Old   November 2, 2012, 05:48
Daniel P. Combest
Take a look at the first post of this thread. Glance through the list of cited posts and you question is answered in
http://www.cfd-online.com/Forums/ope...-parallel.html
decomposepar, directmapped bc, metis, parallel
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 08:19
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 08:00
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 03:58
Regarding periodic BC in ICEM generated grid Tarak OpenFOAM 32 April 30, 2013 14:46
