November 15, 2012, 09:21 |
Cgns support for gmsh
Roberto Pieri
Hello everyone, this is my first thread on the forum and I would like to greet you.
I'm working on my Master thesis with the new software SU2 and I need a mesh in .cgns format. I've just found that by compiling gmsh from source code it is possible to enable cans support. The building of gmsh has been successful, but unfortunately when I try to write the mesh in cgns format some errors occur. I know that cgns support is an experimental tool, nevertheless I would like to ask if someone of you has ever experienced and solved this issue. To be more precise, I post the commands and the errors: roberto@roberto-VirtualBox:/media/sf_Condivisione$ gmsh naca.geo -1 -format cgns -o naca.cgns Info : Running 'gmsh naca.geo -1 -format cgns -o naca.cgns' [1 node(s), max. 1 thread(s)] Info : Started on Thu Nov 15 15:06:43 2012 Info : Reading 'naca.geo'... Info : Done reading 'naca.geo' Info : Meshing 1D... Info : Meshing curve 1 (Line) … Info : Done meshing 1D (0.032002 s) Info : 523 vertices 927 elements Info : Writing 'naca.cgns'... Warning : CGNS I/O is at an "alpha" software stage Error : No mesh elements were found Info : Done writing 'naca.cgns' Info : Stopped on Thu Nov 15 15:06:43 2012 roberto@roberto-VirtualBox:/media/sf_Condivisione$ gmsh naca.geo -2 -format cgns -o naca.cgns Info : Running 'gmsh naca.geo -2 -format cgns -o naca.cgns' [1 node(s), max. 1 thread(s)] Info : Started on Thu Nov 15 15:08:14 2012 Info : Reading 'naca.geo'... Info : Done reading 'naca.geo' Info : Meshing 1D... Info : Meshing curve 1 (Line) … Info : Done meshing 1D (0.032002 s) Info : Meshing 2D... Info : Meshing surface 1 (Plane, Delaunay) Info : Done meshing 2D (0.228014 s) Info : 14015 vertices 28434 elements Info : Writing 'naca.cgns'... Warning : CGNS I/O is at an "alpha" software stage Info : writing BoVerts... Error : Error detected by CGNS library Error : Duplicate child name found: Patch_0003 Info : Done writing 'naca.cgns' Info : Stopped on Thu Nov 15 15:08:15 2012 Thank you in advance! |
July 13, 2016, 11:27 |
#2 | |
Bruno Blais
Rep Power: 12 |
I know this is from four years ago, but have you found the solution to this error ?? I get the same error using the current version of gmsh
Thanks! Quote:
cgns, gmsh, su2 |
SU2 not built with CGNS support. | maximus23 | SU2 Installation | 5 | May 11, 2016 12:05 |
Building from Source on Windows using Cygwin64 | ericthefatguy | SU2 | 2 | May 12, 2015 18:23 |
Compile EnGrid with CGNS support | PierluigiRossi | enGrid | 1 | February 4, 2015 10:30 |
Compiling with CGNS Support | granbycools | SU2 Installation | 6 | March 31, 2014 06:52 |
parallel support with CGNS format not yet implemented | kirkrich | SU2 | 3 | January 18, 2013 15:39 |
