[surface handling] surfaceFeatureExtract many many stl files |
October 10, 2017, 15:39 |
Rep Power: 10 |
is there a way to regroup filenames when writing surfaceFeatureExtractDict ? I usually write something like this: --------------------------------------------------------------------------------------------------------------- Nielsen1979All.stl { #include "surfaceFeatureExtractDictDefaults" } --------------------------------------------------------------------------------------------------------------- but I now have 20 surfaces. I could take the time to write 20 times the same lines but I wondered whether there was a more efficient way. With sHMDict I usually write something like: --------------------------------------------------------------------------------------------------------------- "(walls|hotSurface)" --------------------------------------------------------------------------------------------------------------- However this does not work in surfaceFeatureExtractDict: --------------------------------------------------------------------------------------------------------------- "(walls.stl|hotSurface.stl)" { #include "surfaceFeatureExtractDictDefaults" } --------------------------------------------------------------------------------------------------------------- I hope my question is sufficiently clear. Thank you in advance, Fred |
December 29, 2017, 14:17 |
Peter Hess
Rep Power: 16 |
January 5, 2018, 22:32 |
Rep Power: 10 |
Thank you for your reply Peterhess. I did watch this tutorial, however Calum Douglas does not regroup names. He uses the same method I use (see time 22:35 of the video).
When I think about it, it's not the end of the world. It only takes a few minutes to copy/paste for each stl file. Fred |
January 9, 2018, 11:55 |
Peter Hess
Rep Power: 16 |
I am not sure, if I understand the problem right...
you need to use: splitMeshRegions -cellZones -overwrite after snappyHexMesh if I understood you right! Share your case please! Regards Peter |
January 9, 2018, 20:40 |
Rep Power: 15 |
Maybe I am missing something, but wouldn't the number of files essentially be controlled by the includedAngle that you specify? In my view, the reason one uses surfaceFeatureExtract is because one wants to get separate files. Hence an option in sFE to combine files would seem redundant. Especially since you can reduce the number of features extracted (and hence the number of files) by reducing the feature angle. Just my two cents worth. Cheers, Antimony |
December 20, 2022, 08:42 |
Liangyuan Wei
Hope the solution is useful for new foamers:
this works in surfaceFeatureExtractDict: "walls.stl|walls02.stl|walls03.stl|hotSurface.stl" , just without the brackets for many stl files. |
surfacefeatureextract |
[snappyHexMesh] With FreeCAD: creating waterproof STL files? | robob | OpenFOAM Meshing & Mesh Conversion | 11 | April 29, 2018 11:33 |
[snappyHexMesh] cellzone defined by two stl files | cbarmpar | OpenFOAM Meshing & Mesh Conversion | 0 | March 15, 2015 10:55 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
[OpenFOAM] ParaView 3.6.1 & 3.7.0: Can't view STL files | johannes | ParaView | 2 | December 3, 2009 14:07 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
