addLayers in limited regions of geometry
Hi!
I am dealing with a complex geometry and I need to add layers only in a particular region of this geometry. First of all, I create the background mesh and I used the snappyHexMesh dictionary to model the geometry and to add layers everywhere, except that I obtained a mesh with too many cells. Thus I am asking if someone knows hot to create a sub-region in the .stl file in order to recall it in the addLayersControl and add layers only there. Or can I add layers in a limited region in an other way? In other words, I wonder to be in a situation like this: file.stl //or file.obj (with right header) //STL file name { type triSurfaceMesh; name my_file; // user-assigned name regions // definition of regions of stl { subregion_1 // STL-defined patch name { name my_first_subregion; // user-assigned patch name } subregion_2 { name my_second_subregion; } } } and the addLayersControls would be layers { my_first_subregion { nSurfaceLayers 4; } } but unfortunately I don't know how to define these subregions in my stl file. Thank you in advance, Chiara |
Hi Chiara,
You can split your geometry in 2 different stl files, import them both in snappyHexMesh and insert layers on only one of them. I hope that helps, Eloïse |
Hi Eloise,
I have already split my geometry into two .stl file few weeks ago, exactly as you suggests, and it works very fine! Thank you for the reply, Chiara |
