[snappyHexMesh] Please help me, I am new to CFD and snappyHexMesh
Like Tree2Likes
Old   October 11, 2012, 13:46
Default Please help me, I am new to CFD and snappyHexMesh
Ben
ben1793 is on a distinguished road
Hello
I have made a thread on the OpenFOAM sub-forum in the past about installation problems and turned it into my question thread but after a while I got told I would be better off making a new thread for my questions so here it is
EDIT: I have figured this question out after searching the forum for ages and finding a solution, but I will be asking many more questions soon.
ben1793 is offline   Reply With Quote
Old   October 11, 2012, 15:36
Ben
I have a question now, I am using the motorbike tutorial as a guide and found this:
http://www.vespalabs.org/Projects/Ve...rbike_Tutorial
I have messed around on paraview for ages but cant get it anything like the view on the website, I want it so that I slice through the block (wind tunnel) so that I can actually see the flow over the motorbike while the motorbike itself stays as a solid surface, whenever I try use the slice tool it end up cutting through the bike also, is there anyway I only cut through the block?
Old   October 12, 2012, 03:50
Eloïse
Eloise is on a distinguished road
Hi Ben,
You can try to open 2 objects in paraView: the internal flow field and the motorbike surface. If you use VTK format, then load both files. Otherwise, select both in the Object Inspector. Then, render the motorbike as a surface, and make a cut through the internal field.
You can also find many info in here:
http://www.paraview.org/paraview/hel...de%20v3.10.pdf
I hope this help.
regards,
Eloïse
Eloise is offline   Reply With Quote
Old   October 12, 2012, 07:30
Ben
Thank you for the reply Eloise.
Could you please tell me how to render the motorbike as a surface?
Also, I have been wondering, why is the motorbike tutorial under incompressible flows because the simulation is of a wind tunnel and that is a compressible flow.
If I changed the name of the file in the snappyHexMeshDict file for another stl file would the model in the wind tunnel change or would more things need to be modified, and also, where would I save the stl file?
I am sorry for asking such newbie questions but I have just started out with OpenFOAM and really don't know much about it.
Old   October 12, 2012, 07:48
Eloïse
Highlight the motorbike item in the pipeline Browser, and in the top toolbars change the rendering from "outline" to "surface". If you struggle with other basic features, go through a tutorial such as http://paraview.org/Wiki/The_ParaView_Tutorial
If it is low mach number, you can neglect compressibility effects.
You have to replace the stl file located in constant/trisurface/ directory with your stl file. Your stl must be in ascii stl format (see description of the format on wikipedia) and must be of sufficiently good quality. Try it, you will probably run into some error messages, read them and browse on the forum to see if people had similar issue before.
Good luck !
Old   October 13, 2012, 08:18
Ben
Thank you for the reply.
Old   October 15, 2012, 12:40
Ben
Could anyone please tell me how to run the motorbike tutorial with a different stl model?
I have already converted my model to ASCII and placed it into the trisurface folder
I have also edited the snappyHexMeshDict on the top line and changed it from motorbike.obj to myfilename.obj
I meshed the geometry and used the ./Allrun command to run it and viewed it on paraview, the tunnel was there butmy stl geometry was not in the tunnel.
What have I done wrong?
Old   October 16, 2012, 03:06
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi ben,
have a look at the openfoamwiki http://openfoamwiki.net/index.php/SnappyHexMesh
There you can find some tutorials with sHM! After that it should be clear how to use it. Otherwise you can make a thread in the sHM section.
Regard Tobi
Tobi is offline   Reply With Quote
Old   October 16, 2012, 11:08
Elvis
elvis will become famous soon enough
At least you should write myfilename.stl for an STL-file in snappyHexMeshDict
I think HelxyOS is a great GUI and keeps one away from wrong file names.
You could sometimes get much better results when you use an myfilename.eMesh-file that
you get by using surfaceFeatureExtract command and include that myfilename.eMesh in snappyHexMeshDict as well
elvis is offline   Reply With Quote
Old   October 17, 2012, 16:05
Ben
Thank you for the replies, links have come in very handy. My main concern at the moment is not to get perfect results but it is just to get any results at all.
I have found a guide that told me a bit about creating code in the snappyHexMeshDict file so I copied the code and modified it and got the following:
FoamFile
{ version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object autoHexMeshDict; }
castellatedMesh true;
snap true;
addLayers true;
geometry
{ cara.stl { type triSurfaceMesh; name cara; } };
castellatedMeshControls
{ maxLocalCells 10000000; maxGlobalCells 2000000; minRefinementCells 0; nCellsBetweenLevels 1;
refinementSurfaces
{ cara { level (4 5); } } resolveFeatureAngle 30;
refinementRegions
{ cara { mode distance; levels ((0.1 5) (0.4 4) (1 2)); } }
locationInMesh (3.11 1.51 -1.1); }
snapControls
{ nSmoothPatch 3; tolerance 4.0; nSolveIter 30; nRelaxIter 5; }
addLayersControls
{ layers { cara_vcg { nSurfaceLayers 1; } } }
meshQualityControls
I try this and only my tunnel loads which is what is in the blockMeshDict, my STL file does not show, what have I done wrong?
Also, I did not modify anything in the refinement regions, the location mesh and dont really know what to put in the meshQualityControls, although I will modify the location in mesh once I have actually got the STL model to appear.
Old   October 18, 2012, 04:22
Retired Super Moderator
Bruno Santos
Greetings to all,
FYI: I've mode this thread to the snappyHexMesh sub-forum.
@ben1793: which tutorial are you following now?
Nonetheless, it would be best that you use OpenFOAM's own motorBike tutorial "mesh/snappyHexMesh/motorBike" and work from there.
And as already mentioned before, Helyx-OS would make your life a lot easier since you're new with snappyHexMesh
Best regards,
Bruno
Old   October 18, 2012, 09:10
plucas's Avatar
Anonymous
plucas is on a distinguished road
It is not appearing because your snappyHexMesh is failing. One of the values in the snappyHexMesh file is causing problems creating the mesh and is terminating the process.
plucas is offline   Reply With Quote
Old   October 18, 2012, 09:46
Eloïse
Try this one below...
I deactivated the layer insertion (You don't need that yet), and added some "default" values for mesh quality.
Use the command snappyHexMesh > log.snappyHexMesh and post the log file here so maybe we can help you to see where is the error
Regards,
Eloïse
FoamFile
snap true;
addLayers false;
geometry
refinementSurfaces
refinementRegions
snapControls
addLayersControls
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality 1e-30;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.02;
minVolRatio 0.01;
plucas likes this.
Old   October 18, 2012, 12:35
Ben
Thank you for all the replies and I am sorry that I had posted this question on the wrong sub-forum.
Also, Thank you so much Eloise for taking the time to edit my code
I have used the command in the terminal and got the following error:
--> FOAM FATAL ERROR:
Cannot find file "points" in directory "polyMesh" in times 0 down to constant
From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
in file db/Time/findInstance.C at line 188.
FOAM exiting
I also did not mention, I had changed the size of the external mesh (wind tunnel) in the blockMeshDict file because when I had loaded the tunnel and STL files separately on para view I had noticed that the STL file was much larger in size than the tunnel, so I added two more 0's after every number in the initial part of the blockMeshDict to scale the tunnel by 100.
Old   October 18, 2012, 15:48
Eloïse
The file "points" in the polymesh directory is created by blockMesh. Have you run the blockMesh utility before snappyHexMesh?
Try the following steps:
1) copy the "AllClean" from motorbike tutorial to your case directory
2) run AllClean in your case directory
3) execute the following commands, one by one:
cp -r 0.org 0 > /dev/null 2>&1
blockMesh > log.blockMesh
=> Check in paraView if your windtunnel is as you expect and if your STL is where you want it to be. Play around with the bolckMeshDict until you reach that point.
=> Check the different meshs (times 0, 1 and 2) in paraView to see what was the effect of the castellate and snap steps
Regards,
Eloïse
Old   October 18, 2012, 16:50
Ben
I managed to do everything up till the last step and then a Error:
--> FOAM FATAL IO ERROR:
keyword mergeTolerance is undefined in dictionary "/home/ben/OpenFOAM/ben-2.1.1/run/motorBike/system/snappyHexMeshDict"
file: /home/ben/OpenFOAM/ben-2.1.1/run/motorBike/system/snappyHexMeshDict from line 20 to line 56.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 400.
FOAM exiting
I think I have fixed the mergeTolerance problem by coppying it from another example but now have the following error:
keyword features is undefined in dictionary "/home/ben/OpenFOAM/ben-2.1.1/run/motorBike/system/snappyHexMeshDict::castellatedMeshControls"
file: /home/ben/OpenFOAM/ben-2.1.1/run/motorBike/system/snappyHexMeshDict::castellatedMeshControls from line 28 to line 36.
FOAM exiting
Here is what is inside my snappyHexMeshDict under castellatedMeshControl:
When I used the command you told me to use, it created a new folder called 0, what is the difference between 0 and 0.org?
Is the main reason for creating a log just to see if there is any errors?
Thank you
Old   October 18, 2012, 17:17
Tobi's Avatar
Tobias Holzmann
Its the latest entry in your sHMDict:
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
Just set
into your file.
Differences between 0 and 0.org are that in 0.org your variables (U,T,p...) are and in the folder 0 is your castellatedMesh.
If you have the folder 0.org copyed to 0 with
cp -r 0.org 0
you ll get a new timestep "1" to your case. In that case is the castellatedMesh
in timestep 2 is your snapped mesh
in timestep 3 is your addedLayer mesh (if you use it).
If you set
writeTimestep    100;
into your controlDict
you ll get the folders
100
200
300
and so no.
Build an empty folder 0 befor running sHM.
Then open paraview and you can switch from 0 (backgroundmesh) to 1 (castellatedMesh) to 2 (snapped mesh) and so on.
Tobi
Tobi
Old   October 19, 2012, 04:00
Ben
Thank you for replying Toby and also thank you for answering my questions and clearing things up for me
I have added the code to my snappyHexMeshDict and got the same error when I tried to compile it in the terminal:
FOAM exiting
Old   October 19, 2012, 04:11
Eloïse
If you read the message, it tells you that it misses "features" in castellatedMeshControls. Look at the sHMD in the motorbike totuorial and you will see that there is a line with "feature" which does not exist in your sHMD
Add this:
{ maxLocalCells 10000000; maxGlobalCells 2000000; minRefinementCells 0; nCellsBetweenLevels 1; features();
Next error message you get, try to read it carefully and compare your file to a tutorial file to see if anything is missing
Regards,
Eloïse
Old   October 19, 2012, 05:37
Ben
Thank you Eloise.
I had done as you said and continued changing the snappyHexMeshDict whenever an error came up and finally got it so that no errors come up, but now I have a new problem.
I used the commands you said which created the 0 folder and then used the blockMesh > log.blockMesh and then snappyHexMesh > log.snappyHexMesh and after that used paraFoam, when I went into paraFoam I can see my part under the mesh parts in the pipeline browser, it is right at the bottom under all my other patch's and its called cara_vcg - Patch, when I click apply to view my geometry the cara_vcg vanishes and I am left with just the patch's for my tunnel.
EDIT: I have fixed it, I just ticked the skip zero time box, what does this do?
Also, I have executed the command potentialFoam and simpleFoam as I did on the motorBike tutorial in the past and I did not get a log for simpleFoam so I did it again but this time did simpleFoam > log.simpleFoam, I now have the log but can not view the information I need which is the drag coefficient, I could do this on the motorbike tutorial but for some reason it does not work on here.
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] snappyHexMesh Parallel bad size error andrewpomeroy OpenFOAM Meshing & Mesh Conversion 2 April 2, 2018 01:08
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 11:55
[snappyHexMesh] snappyHexMesh running lguillem OpenFOAM Meshing & Mesh Conversion 7 June 13, 2014 11:28
[snappyHexMesh] Problem with snappyHexMesh samiam1000 OpenFOAM Meshing & Mesh Conversion 0 October 3, 2009 05:08
