[snappyHexMesh] "Jagged" U at refined mesh areas
Old   January 25, 2013, 21:51
Default "Jagged" U at refined mesh areas
Steven Chew
Steven Chew is on a distinguished road
Hi all,
Need some assistance here. I virtually copied the Motorbike case from the tutorial and tried to run using my own vehicle geometry. My case consists of an inlet uniform flow (22m/s) with pressure boundary outlet, and all 4 side walls including the stationary floor.
Running wise I got no problem, and I was able to run snappyHexMesh and simpleFoam and get some results. But when I checked the central cut plane U contour plot, this appears
At the entrance and exit area the velocity magnitude seem to be pretty smooth along the ground, but as it approaches even the first refined mesh, there is this jagged contours.
I do not really understand, and I have checked the motorbike case. The flow parameters I have used including the turbulence numbers are all the same. There are also jagged contour along the ground but it seems more controlled under a thinner layer.
I was suspecting should I increase the number of buffer layers? below is my snappyHexMeshdict file
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers true;
geometry
sunspec.stl
type triSurfaceMesh;
name sunspec;
refinementBox
type searchableBox;
min (-4000.0 -600.0 -1400.0);
max ( 8000.0 1000.0 1400.0);
// Settings for the castellatedMesh generation.
castellatedMeshControls
maxLocalCells 3000000;
maxGlobalCells 3000000;
minRefinementCells 10;
maxLoadUnbalance 0.10;
nCellsBetweenLevels 3;
features
// Surface based refinement
refinementSurfaces
sunspec
level (5 6);
// Resolve sharp angles
resolveFeatureAngle 30;
refinementRegions
refinementBox
mode inside;
levels ((1E15 4));
// Mesh selection
locationInMesh (9700 1700 2100);
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
nSmoothPatch 4;
tolerance 4.0;
nSolveIter 20;
nRelaxIter 5;
// Settings for the layer addition.
addLayersControls
relativeSizes true;
layers
"(walls|sunspec).*"
nSurfaceLayers 1;
// Expansion factor for layer mesh
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.1;
nGrow 0;
featureAngle 30;
nRelaxIter 3;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedianAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality 1e-30;
minArea -1;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.02;
minVolRatio 0.01;
minTriangleTwist -1;
// Advanced
nSmoothScale 4;
errorReduction 0.75;
// Advanced
debug 0;
mergeTolerance 1e-6;
Steven Chew is offline   Reply With Quote
Old   January 28, 2013, 15:07
doubtsincfd is on a distinguished road
Are you adding layers on the ground also?
I also had similar experience, and for me layer addition+second order schemes made the profile smoother
doubtsincfd is offline   Reply With Quote
Old   January 29, 2013, 03:34
Steven Chew
Yes, for this run, I have not put a second layer on the ground. I tested it out and it really smoothened out the jaggedness. Thanks!
But now between the inlet coarse mesh region and the finer mesh region near the vehicle, there is a region of layer 2 mesh (second coarsest) that exhibits this behaviour. Does this mean I actually need to cover the entire ground surface with refined meshing?
Old   January 30, 2013, 09:03
Hi Stewen. Can you post more details of your simulation. Maybe contour plots you did before and fvSchemes file. Also, are you using boundary conditions from motorbike tutorial? They might not be realistic for your problem depending on the dimensions of the geometry.
I would mainly like to know the fvSchemes and the turbulence models you are using
Old   February 10, 2013, 11:01
Steven Chew
Hi, here's my fvschemes file
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linearUpwindV grad(U);
div(phi,k) Gauss upwind;
div(phi,omega) Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
And my turbulence model
FoamFile
version 2.0;
format ascii;
class dictionary;
// location "constant";
object RASProperties;
RASModel kOmegaSST;
turbulence on;
printCoeffs on;
Using mostly the motorbike's stuff except the slip surface and symmetry condition I believe.
The entrance, exit and near-vehicle contours are alright now, but not at the transition, medium-res areas.
Old   February 10, 2013, 20:53
Hi Steven,
I would suggest the following:
1. Refine the mesh in the jagged areas. Maybe the mesh there is not fine enough to resolve the gradients. Seems your layers are thin (which is required for k-w sst), so you can go for more layers if the transition between the near wall layers and the interior mesh is not smooth.
I would suggest to use same refinement near the wall, since the gradients near the wall are highest near the entrance
2. Check y+ values. For k-w SST y+ <=1
3. Use Gauss linearUpwind for k and omega
4. Use cellMDLimited Gauss linear 1 for grad schemes
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
