[snappyHexMesh] working with a digital elevation model |
December 16, 2020, 10:13 |
Theresa
Hello everyone,
I'm very new to CFD and OpenFoam. I'm planning to simulate the flow of a River section. As data basis, I do have a very large DEM in GeoTiff format, which I converted into STL file. I wanted to implement a structure/ bridge as an outlet in the STL. I drew the structure in a CAD program and exported it as STL file. I tried to merge the two STL files in Salome. I created water tight boundaries around the DEM surface. Now I'm having troubles to place the structure STL on the right position and replace a part of the boundary to make a water tight solid, which can be used in the snappyHexMesh utility. Since it is very difficult to modify the STLs in Salome, I wanted to ask if there is a more convenient way, maybe in a CAD program, to work with terrain data to prepare it for the meshing? Thank you so much in advance. Regards, Theresa |
river, salome, snappy hex mesh, stl |
Display Modes | |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
Antti Hellsten model: New Advanced k–ω Turbulence Model for High-Lift Aerodynamics | purnp2 | OpenFOAM Programming & Development | 3 | May 10, 2019 12:29 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
coalChemistryFoam: "Foam::error::printStack(Foam::Ostream&) at ??:?" | musabai | OpenFOAM Running, Solving & CFD | 2 | February 20, 2015 14:07 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
