[blockMesh] Mesh directions - checkMesh results |
January 31, 2011, 20:44 |
Rep Power: 16 |
Hello all,
Can someone enlighten me about the origin of the following message from the checkMesh utility?: This mesh has no valid solving directions. dirs = (-1 -1 -1). Please check mesh definition for empty patches. This is a 0-D mesh Overall domain bounding box (-4 -3 0) (4 3 0.5) Mesh (non-empty) directions (0 0 0) Mesh (non-empty, non-wedge) dimensions 0 ***Number of edges not aligned with or perpendicular to non-empty directions: 22126 <<Writing 11884 points on non-aligned edges to set nonAlignedEdges Has this something to do with the consistency of the axis coordinates when I define my blocks? |
February 24, 2011, 17:41 |
Rep Power: 18 |
TIP: When creating a mesh, frontAndBack patches cannot be set up initially as empty ones. That's the reason of this error. Initially set it up to "patch", then you can redefine it in "polyMesh/boundary" file to "empty".
Hope it solves your problem. Best, K |
November 23, 2011, 03:47 |
#3 | |
wided
Rep Power: 15 |
December 10, 2011, 14:07 |
Mesh moving
Ehsan
Rep Power: 17 |
Hi
I like to move my mesh's cell only by dx/2 and dy/2 and create a new mesh. Could you please help me how to change the blockmesh file to create a new mesh whose cells are moved by dx/2 and dy/2 relative to the first mesh? Thanks a lot |
October 6, 2016, 18:59 |
Anonymouse
Rep Power: 10 |
While this post is really old, but in case it comes up on a google search: I think what you're looking for, for shifting a mesh, is "mergeFields".
April 5, 2018, 19:19 |
#6 | |
Luís Tiago Ferreira Fernandes
Rep Power: 8 |
Luís |
blockmesh, checkmesh, solving directions |
Mesh Independance Test VS Matching CFD Results with Experiments | fadoobaba | FloEFD, FloWorks & FloTHERM | 5 | May 10, 2018 08:49 |
buoyantBoussinesqSimpleFoam - increasing mesh density lead to underestimating results | a_habib | OpenFOAM Running, Solving & CFD | 1 | March 23, 2018 09:07 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
checkMesh Errors after refineMesh | mgdenno | OpenFOAM | 0 | July 30, 2012 21:39 |
