[Commercial meshers] Diffuser Mesh conversion problem, <Fluent3DMeshToFoam> |
August 21, 2013, 10:12 |
tariq
Rep Power: 12 |
Hi everybody,
I want to do a LES simulation of a diffuser using OpenFOAM. The mesh is done by ICEM CFD and now I'm trying convert it to OpenFOAM using Fluent3DMeshToFoam. After the conversion is done when I check the mesh it says "Failed 1 mesh checks". And when I run the simulation using pisoFoam, it says /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0 Exec : pisoFoam Date : Aug 21 2013 Time : 16:01:16 Host : *** PID : 10769 Case : /home/OpenFOAM/run/tutorials/incompressible/pisoFoam/les/Beispiel nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p --> FOAM FATAL IO ERROR: Cannot find patchField entry for DRALL_INLET file: /home/stud-tari/OpenFOAM/stud-tari-2.2.0/run/tutorials/incompressible/pisoFoam/les/Beispiel/0/p.boundaryField from line 25 to line 46. From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) in file /sw/openfoam/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 154. FOAM exiting Couldn't figure out what is going on actually. Do I have to edit any file inside the 0, Constant or System folder? I have just copied and pasted these files from another tutorial and thought the mesh conversion system will make necessary arrangement for the simulation. Please help me out
https://tariqridwan.github.io/ |
August 22, 2013, 00:57 |
Maxime Perelli
Rep Power: 41 |
First fix your check Mesh issue
In memory of my friend Hervé: CFD engineer & freerider |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
mesh quality problem for displacementSBRStress motion solver | zhaozhenkai | OpenFOAM | 0 | January 22, 2017 11:02 |
[ICEM] ICEM Structured Mesh Problem | OMJT | ANSYS Meshing & Geometry | 3 | March 22, 2013 10:06 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
