[snappyHexMesh] SnappyHexMesh error with 2D AMI
Old   June 17, 2013, 01:51
Default SnappyHexMesh error with 2D AMI
Anand Lobo
Boloar is on a distinguished road
Hey FOAMers,
I successfully created a preliminary blockMesh for a 2D VAWT simulation (see attached image), but snappyHexMesh seems to have trouble meshing it with my STL file. This is the error I get:
--> FOAM FATAL ERROR:
cell 0 of level 0 does not seem to have 8 points of equal or lower level
cellPoints:6(0 1 2 3 4 5)
pointLevels:6{0}
From function hexRef8::setRefinement(const labelList&, polyTopoChange&)
in file polyTopoChange/polyTopoChange/hexRef8.C at line 3770.
FOAM aborting
I'm guessing it has something to do with the wedge-shaped blocks that make up the center of the mesh, but I'm a novice at this and I'm not sure how to go about fixing it without remodeling the entire mesh. Any help is appreciated!
I've attached my blockMeshDict and snappyHexMeshDict files for your perusal.
Boloar is offline   Reply With Quote
Old   June 18, 2013, 02:45
Default Kind of fixed ...
Anand Lobo
After adding a hole in the center of the mesh, I was able to get snappyHexMesh to work.
However, there are two problems ...
1) it turns the square blockMesh, in my previous post, into a circle
2) it appears to incorporate my STL model as part of the mesh, rather than as holes / boundaries in the mesh.
(see image here: http://www.cfd-online.com/Forums/att...artialmesh.jpg)
I'm not sure why this is happening. I'm a novice user and I don't have too much free time to understand all of the mesh options, so if someone can point me in the right direction that would be much appreciated.
Thanks!
ami, snappyhexmesh, vawt
mapField error rvl565 OpenFOAM Pre-Processing 1 September 6, 2018 16:13
[snappyHexMesh] OF-2.3.x: snappyHexMesh and AMI A_Pete OpenFOAM Meshing & Mesh Conversion 10 March 11, 2015 13:51
mapFields Error with snappyHexMesh Source Added Layers sherif35 OpenFOAM Pre-Processing 0 September 29, 2014 17:01
snappyHexMesh in parallel with AMI louisgag OpenFOAM Pre-Processing 8 September 15, 2014 02:57
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
