[Other] extrude2DMesh does not work !
Like Tree1Likes
  • 1 Post By l_r_mcglashan
Old   July 5, 2013, 10:12
Default extrude2DMesh does not work !
ooo
ooo is on a distinguished road
Hi
I've converted a 2d mesh from a commercial software to openfoam and now i want to convert it to a 3d mesh(2d with 1 layer in z direction).
I did the same correctly some months ago with openfoam 2.1 but now for 2.2 it does not work.
When i use the command " extrude2DMesh 0.01" i get the error :
--> FOAM FATAL ERROR:
0.01 not found in table. Valid entries:
2
MeshedSurface
polyMesh2D
From function HashTable<T, Key, Hash>:perator[](const Key&) const
I used all formats e.g extrude2DMesh '0.01' and .... but none of the work.
I would appreciate any idea.
ooo is offline   Reply With Quote
Old   July 5, 2013, 10:40
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
You need this dictionary in your system/ folder:
|  \\    /   O peration     | Version:  2.2.x                                   |
FoamFile
    version         2.0;
    format          ascii;
    class           dictionary;
    object          extrude2DMeshDict;
extrudeModel        linearDirection;
patchType           empty;
nLayers             1;
expansionRatio      1.0;
linearDirectionCoeffs
    direction       (0 0 1);
    thickness       0.01;
and run either:
extrude2DMesh MeshedSurface
or
extrude2DMesh polyMesh2D
Depending on whether your initial mesh is a meshed surface or a 2D polyMesh
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   July 5, 2013, 11:06
ooo
FoamFile
    version         2.0;
    format          ascii;
    class           dictionary;
patchType           empty;
nLayers             1;
expansionRatio      1.0;
    direction       (0 0 1);
    thickness       0.01;
and run either:
or
Thank you for your answer.
Would you please tell me how i should compile this code into my system folder?
Also , This is because of the new version of openFoam?because in the previous version i just used extrude2DMesh command.
Thank you in advance.
Old   July 5, 2013, 11:19
You don't compile anything, just put that in the system/ folder of your case directory.
Yes, extrude2DMesh changed to include more functionality.
ooo likes this.
RP_Set_Integer does not work in parallel 86lolo Fluent UDF and Scheme Programming 2 July 3, 2014 11:37
Does CX_Interpret_String work in parallel? 86lolo Fluent UDF and Scheme Programming 2 June 30, 2014 04:36
Companies that lease software & hardware for cloud-based work? Catthan ANSYS 0 June 18, 2014 10:53
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 12:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 21:03
