weird results with featureEdges
3 Attachment(s)
I am using snappyHexMesh and surfaceFeatureEdges extract to mesh a complex pipe with several intets/outlets. My goal is to have first, a good mesh and second, nice surface that can be detected with autoPatch to set up BCs. Unfortunately, the mesh is quite ugly near the featureEdges as you can see on the pictures. I tried to play with the refinement parameters with no success. Any idea on how to improve this ? By the way, is there a way to use these featureEdges to locate BCs instead of using autoPatch ? Attachment 23959Attachment 23961 Attachment 23960 ----edit----- Modifying de skewness parameters made everything work actually ; however, I'm still stuck with my BCs detection method. Even if I try to optimize the angle, the autoPatch still gives me unwanted results like this : Code:
Feature:55 Regards, Florian |
