[CAD formats] from .dwg file to openfoam format |
July 12, 2013, 16:13 |
zaynah K.
Rep Power: 13 |
I have a .dwg file from autocad. I can not export it to .stl format.. can anybody suggest another method on how may i run it in openfoam ? Cheers Zaynah |
August 20, 2013, 05:03 |
Artur
Rep Power: 19 |
You need to convert your file to a 3D geometry in order to be able to export it to an .stl. Depending on what software you have available, you could use Autodesk Inventor (easiest), Rhino (there is an evaluation version you can download for free, at least there used to be), or perhaps AutoCAD itself if your version has 3d modelling features (I've never used AutoCAD for that so hard for me to say if that's very feasible).
Optionally, you can always export your .dwg as an IGES file and use with any other CAD package to create a 3d model. Not sure if that answers your question, perhaps try to be a bit more specific about the problems you're having. Cheers, A Last edited by Artur; August 20, 2013 at 05:03. Reason: spelling |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
