August 29, 2013, 00:15 |
Salome to OpenFOAM patches tutorial
Calum Douglas
Rep Power: 12 |
Hello everyone,
I found this a massive pain in the **** to figure out at first as I am just a beginner with this stuff. So I made a video so others starting out with OF and/or CAE in general have an easier time to figure it out. http://www.youtube.com/watch?v=1zQbU-E4k1U (corrected - Thankyou Nima Sam) http://www.calumdouglas.ch/openfoam/...-7-2-tutorial/ Its just to show how you can get a STEP file into Salome, set up the inlet/outlet/wall patches then import into OF and run it in parallel. Its an interFoam case which is basically a modified version of damBreak. All case files and such are available for download from my website to follow the video. Salome 7.2 OF 2.0.1 Last edited by snowygrouch; August 29, 2013 at 09:08. |
August 29, 2013, 08:59 |
Nima Samkhaniani
Rep Power: 24 |
let me correct the video address :
http://www.youtube.com/watch?v=1zQbU...layer_embedded
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
September 3, 2013, 08:25 |
Adding Prism layer
Himanshu Sharma
Thanks for this useful videos. I wanted to add prism layer in the tetrahedral mesh generated but since i am a new bee i am not able to generate that.Can you please provide some guidance to do it. i just wanted to add prism layer in a pipe with tetrahedral cells to capture boundary layer. Thanks Himanshu Sharma |
September 3, 2013, 12:55 |
Got the solution for adding Prism layer
Himanshu Sharma
HI,
I got the solution in the manual how to add viscous layer in the 3 D mesh.its pretty easy. Regards Himanshu Sharma |
September 3, 2013, 12:56 |
viscous layers
Calum Douglas
Rep Power: 12 |
OK great,
So now make a video and explain so others can do it. C. |
salome salomemeca patches |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
Regarding periodic BC in ICEM generated grid | Tarak | OpenFOAM | 32 | April 30, 2013 14:46 |
Is OpenFOAM tutorial cases valid? | j-avdeev | OpenFOAM Running, Solving & CFD | 3 | September 19, 2012 15:45 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
