[Other] Grid problem
Old   October 2, 2013, 07:43
Default Grid problem
le hoang anh
lehoanganh07 is on a distinguished road
hi ,
I am a beginner in the coding. I will use fortran for my course. I'm trying to make the grid for my model, but when i ran, it had error. I know this forum is for OpenFOAM, but I really need help!
Could you help me to fix it!!
Thank you
program nozzle_mesh
implicit none
real,allocatable,dimension(:,::x,y
integer::i,j,num_xi,num_eta
real::d_xi,d_eta,xi,eta,le,wi,L1,L2,eta0
!eta0 is the hight of base
!L1 is the lenght of base
!L2 is the lenght of combustion chamber
!eta,xi is coordinate in computer plane, eta vetical axial, xi holizon axial
!d_xi; d_eta is distance between 2 node
!i,j is the node
!num_xi;num_eta is number of node
!beta_x;beta_y is the compressible coefficience of cluster grid
!xi0 is the position where cluster compressed in x direction
!xii;etaj distance to origin
real,parameter::e=2.71828
real::beta_x=5.0,beta_y=1.2,anpha,A,xi0,xii,etaj,c ,eta0,x0
open(1,"Nozlle.dat")
read*,le,hg,L1
read*,num_xi,num_eta
xi=hg
eta=le
call number(xi,num_xi,L1)
call number(eta,num_eta,eta0)
d_xi=xi/(num_xi-1)
d_eta=eta/(num_eta-1)
xi0=L1
allocate(x(num_xi,num_eta),y(num_xi,num_eta))
do j=1,num_xi
do i=1,num_eta
xii=d_xi*(j-1)
x0=log((1.0+(exp(beta_x)-1.0)*xi0)/(1.0+(exp(-beta_x)-1.0)*xi0))&
& /log(e)/2.0/beta_x
A=sinh(beta_x*x0)
x(i,j)=xi0*(sinh((xii-x0)*beta_x)+A)/A
if(xii<=L1 .and. i<=eta0/d_eta)y(i,j)=eta0
else if (xii<=L1 .and. i>eta0/d_eta) then
etaj=d_eta*(i-1)
c=log((beta_y+1)/(beta_y-1))
if (xii<=L1) anpha=0
if (xii>L1) anpha=0.5
y(i,j)=((beta_y+1)-(beta_y-1)*exp(-c*(etaj-1-anpha)/(1-anpha))) &
& /((2*anpha+1)*(1+exp(-c*(etaj-1-anpha))/(1-anpha)))
write(1,*),x(i,j),y(i,j)
end if
end do
print*,x(i,j),y(i,j)
end do
end
subroutine number(L,number,L1)
real,intent(inout)::L,number,L1
real::delta
integer::num1,num2
delta=L/(number-1)
num1=L1/delta
delta=L1/num1
num2=L2/delta
L2=num2*delta
L=L1+L2
number=num1+num2
return (L),(number),(L1)
end
File Type: jpg 1385855_659641574054657_1942636461_n.jpg (31.3 KB, 5 views)
lehoanganh07 is offline   Reply With Quote
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
cgns grid problem praveen SU2 20 March 10, 2014 14:09
Grid Independence problem immortality OpenFOAM Running, Solving & CFD 6 May 28, 2013 18:12
Re: Convergence problem for refined grid CFD_Novice Main CFD Forum 13 February 17, 2008 22:56
problem with grid dimension nisheet goyal Phoenics 1 June 18, 2001 09:28
