SALOME to OpenFOAM mesh for SRF/MRF computing
Hello everybody!
I'm trying to import a mesh from salome to openfoam with ideasUnvToFoam utility. However, I do the rotation and can not install zone for MRF or SRF solver. I use Openfoam1.7.1 Where can I read about it? Or can someone tell me how to do it at all? Thank you in advance for your help! |
Nobody can help me?:(
Hi David,
from you post it is not clear whether the conversion with ideasUnvToFoam utility does not work properly, or if you do not know what to do to define the MRF zones? 1. ideasUnvToFoam 2. edit boundary to change patch for MRF zone 3. setSet -batch setBatch 4. setsToZones |
Do you want to rotate the entire mesh, or do you want to have rotational parts and static parts?
If you want to rotate the entire mesh you don´t have to do special zones. I did one SRF simulation. There my whole mesh rotated, and I just used the same mesh as before without any special zones. In a few days I´m going to start a new simulation of a windturbine with rotating turbine and static mast. I´d be glad to hear from you if you do something similar! Best regards Tobias |
HAWT SRF for OF2.2
Hi When you have converted the mesh using ideasUnvToFoam you need to run Code:
splitMeshRegions -makeCellZones -overwrite That will create the different regions named region0, region1 etc. You can then use one of those cellZones inside the dictionaries. |
