[snappyHexMesh] snappyHexMesh layers at the corner missing
Like Tree2Likes
  • 1 Post By chegdan
  • 1 Post By chegdan
Old   February 11, 2014, 08:37
Default snappyHexMesh layers at the corner missing
Yuehan
wc34071209 is on a distinguished road
Hi Foamers,,
I am using sHM to generate mesh, but usually at the corners the layers are missing. Could anybody tell me how to solve this problem?
wc34071209 is offline   Reply With Quote
Old   February 11, 2014, 10:41
chegdan's Avatar
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
When layers are inserted into the mesh, the mesh quality is probably poor and the layers are collapsed. You could
  • make your overall base mesh smaller or bump your refinement level in the corners up a bit
  • Use distance refinement from that surface to refine cells prior to the layer insertion to make small cells so that the mesh quality is not poor enough to cause layer collapse
  • or you could adjust the featureAngle entry in the addlayerControls section to be something like 180. See this presentation for more details, specifically slide44
You may want to start with the last one first....but be careful changing too many things at once to get a desired result. Good Luck!
jylee4 likes this.
Dan
Find me on
Twitter @dancombest
LinkedIn
WordPress
chegdan is offline   Reply With Quote
Old   February 11, 2014, 15:17
Yuehan
Thank you very much.
I have also found that the layers insertion in sHM is very unstable. When I have nSurfaceLayers = 10 then it seems everything is OK, but if I use 15 layers, no layer is inserted. I am totally confused.
Could you provide some hints?
Old   February 12, 2014, 11:32
chegdan's Avatar
Daniel P. Combest
My only hint is that you should slowly add more layers rather than jumping to 150 percent more than where previously successful. You can also try to create a very uniform group of cells where you want to insert layers and this may improve it. Usually, shrinking your base mesh solves many problems with snappyHexMesh. There are many adjustments you can make to the quality measurements but that can make things worse if you aren't careful.
Rasmusiwersen likes this.
Dan
Find me on
Twitter @dancombest
LinkedIn
WordPress
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 05:53
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh mike.franky OpenFOAM Meshing & Mesh Conversion 0 June 3, 2018 09:46
[snappyHexMesh] First try at snappyHexMesh... jaggies, weirdness and missing boundary layers :( KarenRei OpenFOAM Meshing & Mesh Conversion 4 October 15, 2016 19:42
[snappyHexMesh] 2D snappyHexMesh with layers grjmell OpenFOAM Meshing & Mesh Conversion 2 May 27, 2013 12:00
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 07:43
