ccm26ToFOAM problem
I installed the OpenFOAM-2.2.0 in Ubuntu12.04 and ccm26ToFOAM, it gives an error Can someone tell me what is wrong? It is installed in /home/gao/OpenFOAM/gao-2.2.0/platforms/linux64GccDPOpt/bin/ccm26ToFoam I tested with OpenFOAM-2.3.0 and got the same results. Thank you very much! Best regards Zhenlan gao@A:~/Documents$ ccm26ToFoam test1.ccm /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-5be49240882f Exec : ccm26ToFoam test1.ccm Date : Feb 24 2014 Time : 19:09:11 Host : "A" PID : 1928 Case : /home/gao/Documents nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot find file file: /home/gao/Documents/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting |
Hi Zhenlan, when using the ccm26ToFoam utility you have to prepare the whole case (without the mesh of course), i.e. your case directory should contain 0, constant and system sub-directories including all the files as controlDict etc.
Hi, Petr
Thank you for your reply. I figured it out several days later, after I posted the question here. Indeed, we need to create a whole case. I downloaded a file tar.gz in the forum, and copy the mesh in the folder, then it works. Thank you again. Cheers Zhenlan |
