STL for suboff
Hi, everyone
I am using OpenFOAM to simulate the three-dimensional external flow over a submarine. Now , I plan to use snappyHexMesh to generate the mesh, so a surface data profile formatted in STL corresponding to the submarine model is required. However, I do not know how to produce such a STL file for the submarine. Shall I need some kind of software to export this STL file? If so, shall anyone kindly recommend a proper software? Thanks in advance! |
Hi
If you have the cad part in STEP/IGES/BREP you can use Netgen, Gmsh or Salome to import the geometry and mesh the surface and export to 3D stl. |
Hi, Linnemann ;
Thanks for your help. At present, I do not have the cad part in IGES/STEP/BREP file, so I guess I need a software such as Freecad or Blender or BRL-CAD to generate this file that contains the geometry information for the suboff model? |
1 Attachment(s)
Hi
I just went through the original paper for the DARPA SubOff model and could not resist making a program that works with Salome 7.3.0. :D You can download the script here. https://github.com/nelinnemann/Salome-Scripts The geometry can easily be meshed with the Salome Mesh Module |
Hi, Linnemann
I am very appreciated for your valuable help. It does help me a lot ! Best regards. Jianjun |
