snappyHexMesh - parallel processing problems
When I run snappy regularly everything is fine. As soon as I use decomposePar, the resulting mesh is the same as that of blockMesh. Is this a simple fix?
You first need to copy the mesh in the last time directory created by snappy to the constant/polyMesh folder. Or alternatively run snappy with the '-overwrite' option.
Cheers, L |
after running reconstructPar -latestTime, no new folders are being made? All I have is 8 processor folders and the 0, constant, and systems folder. I feel like a new time folder should be created correct?
Dear B,
if you use -overwrite, no new folders (1,2,3) are created. Instead 0 is overwritten. Best regards Julian |
when I run snappy with -overwrite I cannot get recontructPar to work?
blockMesh
decontructPar -force foamJob -parallel -screen snappyHexMesh -overwrite reconstructPar -zeroTime ---> gives error: Size of maps does not correspont to size of mesh for processor 0 reconstructPar -latestTime ---> gives error: No times selected when I run without overwrite, two new times folders are created within each processor (one for mesh, one for snap), but reconstructPar does not create new times folders in the directory. when I run with overwrite, no new times folders are created within each processor, and I cannot use reconstructPar. again, if I just use snappyHexMesh, everything works out perfectly. Could this have to do with the way decomposePar is splitting up the mesh? the piece I am adding is not evenly distributed. |
Try
reconstructParMesh -noZero -constant -mergeTol 1e-6 Best regards Julian |
RULI you're the best! Worked like a charm.
