Understanding the Propeller tutorial
2 Attachment(s)
I've recently started with OpenFOAM (2.3.0) and want to simulate rotating propellers. I'm looking at the propeller tutorial and trying to understand how AMI patches are generated. I've tried to use SHM to do my own geometry but when I look at the two AMI patches, they look quite different. As far as I understand in the propeller tutorial they both come from the innerCylinderSmall geometry and the AMI is created using topoSet?:confused: Could someone explain why if they can be different when I look at my own cylinders in ParaView, aren't the same mesh refinements applied in SHM? Do I have to work with the topoSet and createPatch dicts to work around this or is this a matter of mesh refinment? thank you for any hints on this Martin Attachment 29827 Attachment 29829 |
Are you naming them the same way? Make sure you have the explicit feature edge section of the snappyHexMeshDict set correctly, and that your surfaceFeatureExtractDict is also correct. Beyond that, I've had luck increasing the number of feature snap iterations from 10 to around 50.
Hi, thanks for your hints.
I've got it working with a new stl file and not specifying explicit feature edges at the moment. I will try increasing the iterations if I run into similar problems while refining further. Yes, I'm following the tutorial. They both come from my innerCylinderSmall.stl file. I'm actually wondering where exactly the innerCylinderSmall and innerCylinderSmall_slave come from i.e at what stage these are generated and how? |
Yes, I was just wondering if anyone has some more information as to when these are generated as it seemed the two patches came out differently in my case. I'm just wondering why for one of the AMIs the edges are different to the other one.
