April 5, 2014, 02:43 |
Error during PitzDaily case
harshawardhank
Rep Power: 13 |
Hello Friends
I am getting following error in pitzDaily case after entering blockMesh command. --> FOAM FATAL IO ERROR: attempt to read beyond EOF file: /home/ict/OpenFOAM/pitzDaily/constant/polyMesh/blockMeshDict.boundary at line 87. From function ITstream::read(token&) in file db/IOstreams/Tstreams/ITstream.C at line 83. FOAM exiting |
April 11, 2014, 23:30 |
Fumiya Nozaki
Rep Power: 18 |
Hi
Did you resolve your issue? This error says that there is something wrong in your blockMeshDict file. Please attach the file if you need some help. Best regards, Fumiya
[Personal]
April 12, 2014, 02:12 |
harshawardhank
Rep Power: 13 |
Hello dear,
I got the issue, I did not put semicolon after face co-ordinate entries |
Unphysical pressure field in LES PitzDaily tutorial case | bling | OpenFOAM Running, Solving & CFD | 3 | March 9, 2021 02:53 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Reporting a bug in Allrun script on wingMotion case | i.sabahi | OpenFOAM Bugs | 0 | June 10, 2018 09:00 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 11:20 |
