November 24, 2020, 11:21 |
blockMesh, mergePatchPairs
Nikhil
Rep Power: 5 |
Hallo foamers,
I have 5 blocks, which have to be joined together and form 1 block. Only the faces exposed to the outside are supposed to be defined as patches. So, I want to merge faces that are in the middle of the domain. I tried to use mergePatchPairs for that, but unable to merge all patches. The following figures explain the problem more in detail. The yellow faces in the figure have to be merged (to internal faces) and blue faces have to defined as patches. blockMesh file is attached below. I used mergePatchPairs to merge faces, but it works for only any one of the blocks. for example, if I merge face from block 1 to face from block 2 then I cant merge the face from block 1 to face from block 3, don't know why it's not working. Is there any way to do this? Please someone shed some light on this. cheers, nick. Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( //block01 (-15 0.12 0.00)//0 ( 15 0.12 0.00)//1 ( 15 20.0 0.00) (-15 20.0 0.00) (-15 0.12 8.00)//4 ( 15 0.12 8.00)//5 ( 15 20.0 8.00) (-15 20.0 8.00) //block02 (-15 -0.40 0.00)//8 (-1 -0.40 0.00) (-1 0.12 0.00) (-15 0.12 0.00)//11 (-15 -0.40 8.00)//12 (-1 -0.40 8.00) (-1 0.12 8.00) (-15 0.12 8.00)//15 //block03 (-1 -0.40 0.00) (5.0 -0.40 0.00) (5.0 0.12 0.00) (-1 0.12 0.00) (-1 -0.40 8.00) (5.0 -0.40 8.00) (5.0 0.12 8.00) (-1 0.12 8.00) //block04 (5.0 -0.40 0.00) (15 -0.40 0.00)//25 (15 0.12 0.00)//26 (5.0 0.12 0.00) (5.0 -0.40 8.00) (15 -0.40 8.00)//29 (15 0.12 8.00)//30 (5.0 0.12 8.00) //block05 (-15 -20.0 0.00) ( 15 -20.0 0.00) ( 15 -0.40 0.00)//34 (-15 -0.40 0.00)//35 (-15 -20.0 8.00) ( 15 -20.0 8.00) ( 15 -0.40 8.00)//38 (-15 -0.40 8.00)//39 ); blocks //(0 1 3 2 4 5 7 6) ( hex (0 1 2 3 4 5 6 7) (60 60 20) simpleGrading (1 1 1) //block1 hex (08 09 10 00 12 13 14 04) (60 60 20) simpleGrading (1 1 1) //block2 hex (16 17 18 19 20 21 22 23) (60 60 20) simpleGrading (1 1 1) //block3 hex (24 25 01 27 28 29 05 31) (60 60 20) simpleGrading (1 1 1) //block4 hex (32 33 25 08 36 37 29 12) (60 60 20) simpleGrading (1 1 1) //block5 ); edges ( ); boundary ( bt01 { type empty; faces ( (0 1 5 4) ); } bt02 { type empty; faces ( (00 04 14 10) ); } bt03 { type empty; faces ( (19 23 22 18) ); } bt04 { type empty; faces ( (27 31 05 01) ); } up05 { type empty; faces ( (08 12 29 25) ); } up02 { type empty; faces ( (8 9 13 12) ); } up03 { type empty; faces ( (16 17 21 20) ); } up04 { type empty; faces ( (24 25 29 28) ); } rt02 { type empty; faces ( (9 10 14 13) ); } rt03 { type empty; faces ( (17 18 22 21) ); } lt03 { type empty; faces ( (16 20 23 19) ); } lt04 { type empty; faces ( (24 28 31 27) ); } ); mergePatchPairs ( (up05 up02) (up05 up03) (up05 up04) // (bt01 bt02) (bt01 bt03) (bt01 bt04) // //(rt02 lt03) //(rt03 lt04) // ); |
blockmesh, facematching, mergepatchpairs |
[blockMesh] mergePatchPairs with blockMesh | Ivanet | OpenFOAM Meshing & Mesh Conversion | 17 | May 4, 2021 10:32 |
[blockMesh] blockMesh | MergePatchPairs | snappyHexMesh |Different number of cells in divisions | pythag0ra5 | OpenFOAM Meshing & Mesh Conversion | 1 | September 19, 2020 14:38 |
[mesh manipulation] mergePatchPairs after running blockMesh | ashishmagar600 | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2019 04:15 |
[blockMesh] Error running blockMesh with mergePatchPairs on OF2.4.0 | deepbandivadekar | OpenFOAM Meshing & Mesh Conversion | 1 | November 25, 2017 14:50 |
[blockMesh] BlockMesh documentation User Guide clearance of mergePatchPairs proposals | benru | OpenFOAM Meshing & Mesh Conversion | 0 | June 9, 2008 02:22 |
