[Gmsh] gmshToFoam command
Old   April 22, 2014, 17:32
Default gmshToFoam command
Mauricio Vinassa
mvinassa is on a distinguished road
I am new in OpenFOAM, meshing and CFD, and I am doing my first steps into programming.
The thing is I need to transform the elements generated using Delaunay into gmsh to Voronoi elements. After a long research, I found that maybe gmshToFoam could help me to get a voronoi mesh.
I have a few questions:
1- am I right thinking that gmshToFoam would transform my Delaunay triangle into my Voronoi elements? My model currently has more than 7 MM elements, of course I need to simplified it, but still its wanna be a big model.
2- are you aware of any better method to transform Delaunay into Voronoi?
3- Do you realized where my mistake could be and why can't find the file? Trust me the file location is fine (Home->OpenFoam->mv-2.3.0)
I have been trying with this command but the following mistake appears:
ubuntu@ubuntu:~$ gmshToFoam /Home/OpenFoam/mv-2.3.0/cube.msh
| \\ / O peration | Version: 2.3.0 |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : gmshToFoam /Home/OpenFoam/mv-2.3.0/cube.msh
Date : Apr 22 2014
Time : 16:10:52
Host : "ubuntu"
PID : 13058
Case : /home/ubuntu
nProcs : 1
Create time
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/ubuntu/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
I really appreciate any help you can give me with this.
Thank you very much
mvinassa is offline   Reply With Quote
Old   April 25, 2014, 07:36
Default cannot find file 'controlDict'
Richel Bilderbeek
assert is on a distinguished road
The error is here:
cannot find file
Solution: add a file called 'controlDict' in the folder '/home/ubuntu/system'.
To give you a head start, here is an example, but Google yourself to suit your needs
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application            sonicFoam;
startFrom           latestTime;
startTime           0;
stopAt              endTime;
endTime             7e-3;
deltaT                 1e-8;
writeControl        adjustableRunTime;
writeInterval       1e-6;
purgeWrite          0;
writeFormat         ascii;
writePrecision      6;
writeCompression     uncompressed;
timeFormat          general;
timePrecision       6;
runTimeModifiable     yes;
adjustTimeStep       no;
I will never accept a 'Friend' request, I will always accept beer
assert is offline   Reply With Quote
delaunay voronoi, gmshtofoam problem
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
