Wedge shape meshing problem!
Hi everyone. I am trying to build a wedged-shape(or you can say pyramid-shape) geometry like the one in Table 5.1 in the Manual. However I couldn't achieve this. I used the same structure given in the Manual 5.3.3 but I get an error as of below:
face 1 in patch 0 does not have neighbour cell face: 4(1 2 4 3) I do not know what it means I checked my vertices and assigned them anti-clockwise. Here is a copy of this small mesh. Can you help me about it? vertices ( (0 0 0) (11.18111 4.98 0) (11.18111 -4.98 0) (11.18111 -4.98 1.7) (11.18111 4.498 1.7) ); blocks ( hex (0 1 2 2 3 4 4 3) (20 20 20) simpleGrading (1 1 1) ); edges ( ); boundary ( fixedWalls { type wall; faces ( (0 1 2 2) (1 2 3 4) (0 1 4 4) (0 2 3 3) ); } fixedWalls { type empty; faces ( (3 4 4 3) ); } ); |
I'm new to OpenFOAM but I tried to understand your problem. I think the fifth coord is 4.98 (instead of 4.498). Then which form do you want to create with 5 points ? I thought it could be only the pyramid or the tet-wedge (according to the user guide). And another issue is that the number of faces have to be lower than the number of vertices. (One more time, I guess, except if you create internal faces) Maybe someone else can respond... Victorien |
problem was in the definiton of the hex block. It should work, if you use this code:
vertices |
