August 4, 2014, 19:58 |
Save mesh from command line in gmsh
Jefferson Vieira
Rep Power: 11 |
Hi all,
I need to read a stl file and save it as geo from the command line. Does anyone know how to do it? Thanks in advance, Jefferson |
August 5, 2014, 10:24 |
Jefferson Vieira
Rep Power: 11 |
I just solved it.
Actually the output file didn't need to be .geo, it could be .msh, so I just used th following code: Code:
gmsh <input file> -1 -o <output file>.msh |
geo, gmsh, mesh, save, stl |
GMSH extrude a boundary layer from an unstructured Mesh | Hillie | Mesh Generation & Pre-Processing | 2 | July 7, 2017 03:38 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[Gmsh] STL on Gmsh + Mesh on Snappy | adrieno | OpenFOAM Meshing & Mesh Conversion | 3 | May 20, 2016 12:22 |
[Gmsh] background mesh in gmsh | Nick_J | OpenFOAM Meshing & Mesh Conversion | 1 | March 20, 2013 04:20 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
