application of ASCII STL in different systems
Hi, everyone,
I plan to use snappyHexMesh utility to produce computation grids, and first, a geometrical ascii stl file is needed. Now, I use a CAD software in a Windows system to produce the stl file. However. the openFoam has been intalled in the Opensuse Linux system. So, my question is whether the stl file can be directly recognized and used by the snappyHexMesh? If not, what procedures shall I take to make use of this stl file ? Any help is greatly appreciated. Kai |
Hello Kai
The stl file from Windows works perfectly with Linux. But you should export the stl file as ASCII stl (you can choose between binary and ASCII in your CAD program). After that the ASCII should look like the following Code:
solid Please feel free to ask if you have any further questions. Best Regards, Mike |
Hi. Mike.
Thanks very much for your kind help. I guess that you have made a test to validate the perfect suitability of ascii stl file in windows to linux. Next. I will confidently constuct my model in a CAD software. Best wishes. Kai |
