Problem creating patches using snappyheymesh
1 Attachment(s)
Hi everyone,
i got a problem defining patches using SHM. I have a tube and a rotor in the tube. Both as STL. I end up having a "tube" and a "rotor" patch. What i need now is a separated inlet and an outlet patch (marked red in the image). And further i have to split the part of the mesh containing the rotor to let it rotate with cyclicAMI (marked yellow). Can anybody tell me how to realize this case? If you need any further info, just let me know. Thanks! Mario http://www.directupload.net/file/d/3...rz7zmu_jpg.htm |
i add my snappyHexMeshDict:
/*--------------------------------*- C++ -*----------------------------------*\ |
hi everyone,
okay now i figured how to get a inlet and outlet using "autoPatch". But now i am stuck trying to get faces inside the tube for the rotor part. I suppose it works somehow using "createPatch" ? But i am really not sure if this is the right way. Do i even need a boundary there for letting the inner part rotate. Or do i have to split the mesh? Some input would be nice, the tutorials aren't that clear to me :/ thanks! |
nobody at least a little hint?
